Old 27th April 2003, 11:34 AM   #1
Toster's Avatar
Default LM3886 and it's quiescent current
I've made a prototipe amplifier with inverted LM3886. I have 21V dual secondary 300VA transformer
and 19000uF per rail for now, maybe I'll take quarter of that on the end or who knows. It is going
to fit in the box I have this way or the other one. I've made a tiny PCB (40x44mm) for it.
When I measured the DC offset, great, only 1.4mV, but I'am not sure if it is oscilating, because
there is 50mA drown from minus of PS, and 50 from plus with no load. I remember reading from the
datasheet that the total quiescent current is 50mA, but I'am not sure if it means 25mA from +,
and 25mA from - of PS? Otherwise it could be the oscilations that I'am not in position to detect
because I have no osciloscope.
I need some help.
Tomorrow I'll probably post a photo of PCB and the prototipe.
thanks,
mario
Old 27th April 2003, 10:59 PM   #2
moamps is offline moamps  Croatia
Hi, Mario
from app. note for LM3875:
Total Quiescent Power Supply
Current (VCM = 0V, VO = 0V, Io = 0 mA) tipical is 30, max. 70 mA.
You are in limits. If you wish detecting oscillation, use half wave rectifier with some signal or small shotky diode and ceramic cap ca 100nF in parallel with ca 1ME resistor and measure with multimeter on DCV range voltage on output cap 100nF. If you have reading some (when input of amp is grounded or without signal) voltage(larger than 1V) , this means that you have oscillation.
Or, simplest way, put Zobel network on output (RC 10E+100nF) and observe current, if go smaller than you have oscillation.
Old 1st May 2003, 06:52 PM   #3
Toster's Avatar
Thanks moamps.
I'll try that when I find some time. Till then I leave you all with a few photos of my PCB.
mario
Old 1st May 2003, 06:53 PM   #4
Toster's Avatar
....and the front side
Old 2nd May 2003, 04:31 PM   #5
Banned
Question Mmmmmm....
Where do you put the PSU caps?
No PSU caps on that circuit?
You should have something near the supply pins of the chip, or else you may have (severe) oscillation.
Old 5th May 2003, 10:23 PM   #6
Toster's Avatar
Default Re: Mmmmmm....
The PSU caps are hooked on the PCB with 10cm of wire.
But I think that I will follow your advice and soldier
something like 220uF per rail directly on the PCB.
tnx,
mario
Quiescent current question? thanks crippledchicken Solid State 29 18th June 2005 09:58 PM
LM3886 Quiescent current NITRO Chip Amps 4 20th April 2005 10:06 PM
quiescent current different on both channels? crippledchicken Solid State 6 21st November 2004 02:55 AM
P3a No quiescent current! PetarLD Solid State 9 17th February 2004 01:20 AM
Quiescent Current JohnClark Solid State 13 16th November 2001 08:20 PM
Page generated in 0.08622 seconds (78.90% PHP - 21.10% MySQL) with 11 queries
