Old 4th May 2009, 11:32 AM   #1
Default LM1875 power on POP problem
Just asembled an LM 1875 GC,
At start up / power on there is a POP and the speaker cones
move back and forth.
It sounds great and am happy with it but am a little worried
about damage to the speakers.
Is there anything I can do to prevent this happening.
Thank you
Andrew
Old 4th May 2009, 10:14 PM   #2
Minion is offline Minion  Canada
I believe this is caused by a momentary DC offset that happens as the PSU and Caps are chargeing and voltage is stabilizing ...
It won"t hurt your speakers but it is anoying , to eliminate it I believe you would need a soft Start curcuit ....
Most of my amps have that turn on thump and it hasn"t caused any problems and the initial noise doesn"t bother me .....
if you do a search arround here for a soft start curcut you will probably find one ....
Cheers
Some of my amps have a turn off thump accept the thump happens about 1 min after I turn it off .....
Old 4th May 2009, 10:57 PM   #3
Minion thanks.
I'll search around for this and investigate.
I also read a thermistor may slow the current inrush down
a little but would prefer more protection, so I'll take your advice.
Thank you for the info
1 minute for yours ?
That's a long time :-)
Your amps are large and surely not small Gainclones ?
Andrew
Old 4th May 2009, 11:53 PM   #4
Hi, No problem , Actually they are chip amps , this one in particular is a TDA7293 100w chip with 40,000uF In the PSU , when the caps are finally fully discharged the amp pops and goes quiet .......
Cheers
Old 16th May 2009, 07:08 AM   #5
Default Re: LM1875 power on pop problem
Hey Andrew,
I also built an amp with this IC. Mine makes the same noise upon powering up and as the power supply caps discharge. I am using a regulated supply with mine, and it makes most of its noise as the supply caps discharge. Like mentioned before, its of no consequence to your speakers, but if you were to use it with an active system, I would recommend using a series cap with the tweeter. Another solution to get rid of the noise upon powering up is to have a relay based muting circuit. There are a couple of these offered as boards or complete kits. Velleman and Rod Elliott (sound.westhost.com) offer them.
They do sound nice, don't they?
Cheers, Jon 'Uncle Olaf'
Old 16th May 2009, 02:52 PM   #6
jb74 is offline jb74  United States
Default LM1875 pops
Here's a link to a circuit that is working for me with a DIY stereo amp using LM1875's:
http://www.epanorama.net/circuits/ampdelay.html
When the amp is turned on, there is a short
delay of a second or so before sound is heard
from the speakers.
When the amp is turned off, sound from the
speakers stops with no delay.
Result - no pops, etc., at either turn-on
or turn-off using LM1875 chips.
Old 16th May 2009, 04:40 PM   #7
Hey Jb,
Thats a neat little circuit. Thanks for sharing it. I'll give it a try.
lm1875 PS/Transformer problem :/ fr1s Chip Amps 12 6th March 2009 10:41 PM
Power supply for 5 LM1875's mangrovejack Chip Amps 10 24th April 2005 07:59 AM
lm1875+battery problem PauSim Chip Amps 38 6th February 2004 02:45 AM
LM1875 problem soundNERD Chip Amps 1 28th November 2003 01:52 PM
hum problem with LM1875 JAZZ2250 Solid State 1 13th February 2003 06:42 PM
Page generated in 0.08393 seconds (76.81% PHP - 23.19% MySQL) with 10 queries
