| Chip Amps Amplifiers based on integrated circuits |
#2 |
Any luck finding the answer?
#3 |
Not sure about branded but LME498xx Driver and Power Boards Group Buy
#5 |
Any luck with this, Panson?
Shaun Onverwacht |||||||||| DON'T PANIC |||||||||| |
#7 |
Dear Panson,
It almost happened in a commercial France (you can guess the brand) active loudspeaker where I design the amplifiers for... but on last moment we decided to go for the LM4702. Subjectively speaking, the LM4702 sounds more "magic" then the LME49810 on the Sanken STD03. With kind regards, Bas |
#8 | |
Did you compare 4702 and 49811? Cheers, Panson |
#9 |
Dear Panson,
Yes we did. To be honest in my subjective opinion they sounded the same (despite the fact the LME49811 can deliver slightly more current). I like both 4702 and LME49811 more then the LME49810, but I have to say, all chips sound very good, this is nitpicking and also depends on personal taste. The reason we choose the LM4702 in first instance was more for economical reasons (two channels in one chip, and one heatsink). However it turned out that I love the sound endless and it was an improvement over the LME49810 we used in the first prototype. Just be sure you use the Y version of the STD03's with the highest hFE, to keep distortion of the LM4702 low. It needed some tweaking though. The STD03 needs a pre bias of 2.5mA through it's tempo diode string. Standard the LME4702 gives to much voltage on it's Source and Sink pins. Trim it with just a resistor between source and sink works of course but wasn't totally satisfying for me. (sound-wise and stable current source) I end up with using a red LED (vf 1.9) in series with a resistor between Source and Sink to set the current on 2.5mA. This works very well, constant, stable and sound significant better then using just a resistor. I will try to add some pictures later this week. Last but not least, We set the idle bias on 12,5 mV over each Re (Re is 0.22R). Thermal tracking seems very good, and stabilize fast after full power operation. With kind regards. Bas Last edited by Sebastiaan; 29th September 2010 at 07:39 AM. |
#10 |
Dear Bas,
I heard that 4702 is essentially a dual version of 49811 with some layout changes. Is that a floor standing active speaker? How many ways? I am also trying active XOR, currently using dbx 234XL and my amps for two-way. Cheers, Panson Last edited by panson_hk; 3rd October 2010 at 11:01 PM. |
| LME498xx Driver and Power Boards Group Buy | panson_hk | Group Buys | 3 | 20th July 2009 02:36 AM |
| Mullards branded as Telefunkens??? | safetyman | Tubes / Valves | 7 | 10th August 2005 03:46 AM |
| pro amplifiers vs. home audio amplifiers | bonsai171 | Solid State | 26 | 25th February 2004 08:24 PM |
| Paradigm amplifiers? Anthem amplifiers? | Corn-Picker | Solid State | 2 | 24th January 2004 03:10 AM |
| Many smaller amplifiers vs. bigger amplifiers. | djdan | Solid State | 9 | 17th September 2002 04:40 PM |
