| Chip Amps Amplifiers based on integrated circuits |
thought i should start a thread of my own...although a simmilar one exists by BrianGT..
#2 |
I have made a pcb using national's art work as a guide, it may not be upto scratch..it works without any hum hiss and sounds good too.. comments welcome..
#3 |
the pcb with components in place...a few changes have been made after the pic..decoupling caps near IC replaced with monolithic ceramics in place of film.
#4 |
I like the way the chip is mounted, thats waht i need for the system I'm building. How does it sound?
#5 |
sounds pretty good...the benchmark being my earlier amp based on TDA1514A and my Sony DHC-AZ55D. It's dead silent...no hum no hiss at all !
#6 |
btw although the way the chip is mounted will remain that way , I will be using a larger heat sink in actual use..it's twice as large.
#7 |
have another look at the trace and lead lengths connecting C1 to C2, the HF decoupling.
The traces are too long resulting in excessive inductance.
regards Andrew T. |
#8 |
ya...tat ground trace is a bit long,but the caps are close the chip pins for +ve and -ve rails. I haven't had any issues though, with oscillations even with inputs open....which would occur with inductance in traces.. right ?
#9 | |
The zero volts of the decoupling should be connected to each other. It's the way the currents want to flow. The decoupling is like a temporary battery for very short term transients.
regards Andrew T. |
#10 |
good work,
did u assembled the PCB once send by me, how did that sound compared to this reference schematic
. . .. ... ..... ........ ............. ..................... .................................. My Best LM3886 PCB layout |
| how to determine sensitivity of two drivers wired in paralell? | audiophile36 | Full Range | 13 | 26th March 2008 11:02 PM |
| Paralell LM3886 | MadFinn | Chip Amps | 39 | 28th December 2007 07:42 AM |
| paralell connection of transformer ofr ucd180 | bcrazy | Class D | 0 | 1st January 2007 12:46 PM |
| paralell gainclone not working | 40Watts'n beer | Chip Amps | 19 | 1st October 2004 01:17 AM |
| Page generated in 0.09234 seconds (76.83% PHP - 23.17% MySQL) with 11 queries |
