Old 30th April 2009, 11:19 PM   #1
Default PA150 (3x LM3886) 2 ohm capability ?
Hello !
I buy PA150 (3x LM3886) but I don't know if this board is able to load 2 ohm ?
If you know what's parts change to make PA150 2 ohm capability please help me !
In the national.com sheet I don't find any spec on PA150 but the PA100 and the BPA200 have 2 ohm capability version.
thanks in advance for your help !
nicK
Old 1st May 2009, 08:14 AM   #2
Depends on the supply voltage. According to AN-1192 PA-100 is 2 Ohm stable with up to ±28 V rails.
Assume ±38 V rails for PA-150. A nominal 2 Ohm speaker can dip down to 1,6 Ohm. 38 V / 1,6 Ohm = 23,75 A. 23,75 A / 3 = 7,92 A, which is just below the 8 A current limit. A bit close for comfort, but PA-150 should therefore be 2 Ohm stable at all supply voltages provided that the heatsink is big enough.
If you assume ±38 V rails, the three ICs have a worst case dissipation of ~150 W, requiring a total thermal resistance below 0,033 K/W. Quite unrealistic, when the IC itself already has 1 K/W (T-type) or 2 K/W (TF-type).
Either keep the rails at or below ±33 V for PA-150 or build PA-250 or PA-300, so that the 150 W are distributed across 5 or 6 ICs.
If you've always done it like that, then it's probably wrong. (Henry Ford)
Old 1st May 2009, 12:13 PM   #3
THANK YOU SO MUCH FOR YOUR ANSWER !!!
nicK
Old 15th September 2010, 05:33 PM   #4
DarpMalone's Avatar
I have a spare PA150 board and 2* 31.5VDC / 3.17A power supplies that I'm currently not using... I also have (2) 4ohm woofers so I'm thinking I can build a nice little 150W sub amp for a 2Ohm load.
Q1) Am I correct in thinking that this would be a good match for 2 Ohms? If I understand the AN-1192 notes correctly, in a PA150 config, each chip should see 6Ohms
Q2) Can I create a dual 31.5v supply by joining the (-) of PS1 to the (+) of PS2 [creating my (0) feed], then using the (+) of supply1 and (-) of supply2 for the PA150's +/- (does this present issues with ground? will I fry the PS's by doing this)?
I also have a 36VCT transformer that I guess could work, but I'm guessing the voltage would be a bit low.
Old 15th September 2010, 06:29 PM   #5
DarpMalone's Avatar
I guess I can't edit my post.
I've discovered that joining the 2 PS's is not as straight forward as I thought and it depends a lot on if, and how they are connected to earth, so I'll leave that alone.
Old 15th September 2010, 08:21 PM   #6
It would be enough for more than 100 W, provided the transformer has enough power. 100 W means less than 2 dB difference compared to 150 W.
Only for a limited amount of time after writing it.
That is right. Usually the negative connection is grounded and you cannot connect two of those SMPS in series without modifying at least one of them.
Anyway 3,17 Apk would not be sufficient for 150 W into 2 Ohm which takes 8,7 Aeff (> 12 Apk) without taking peak current demands into account.
Old 15th September 2010, 08:39 PM   #7
DarpMalone's Avatar
That's good news. It's a 180VA transformer. So I can still throw this thing together after building a supply.
Thanks for your reply.
I guess I'm not understanding the concept correctly... If each chip see's 6Ohms, when paralleled, and I'm using 31.5v rails, wouldn't the current demand be much less? (8A from 31.5V rails would be a 500W supply!)
I thought I was beginning to figure this out
Old 16th September 2010, 12:17 AM   #8
Rounding to 30V for sake of ease:
30V / 6R = 5A (each IC)
30V * 5A = 150W (still each IC)
150W * 3 = 450W
It doesn't matter from the math perspective whether it's 3 chips seeing 6R or 1 chip seeing 2R. The important part is you spread out the current draw and the heat dissipation.
You weren't wrong with 500W. But that's peak and you don't really need a power supply that large unless you plan on pushing the amp hard.
Tyler
Old 16th September 2010, 02:10 AM   #9
DarpMalone's Avatar
150W * 3 = 450W
Hi, again, Redshift187
I'm certainly not trying to argue or challenge, I'm still confused and trying to understand the logic... The 150w should be spread between the 3 IC's, not each (50W x 3 totaling 150W, not 450W), so why are they drawing 3x the total required current?
Old 16th September 2010, 02:54 AM   #10
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via MSN to abraxalito Send a message via Yahoo to abraxalito Send a message via Skype™ to abraxalito
The 150W is a peak power, not sinewave or music power. So the requirement for this current from each IC (5A) is very shortlived.
I think ideas are what you want to get rid of. I don't really like songs with ideas. - Leonard Cohen
PA150 PCBs, is there any interest CJ900RR Chip Amps 40 16th April 2009 04:25 PM
PA150 review FlexQ Chip Amps 3 6th March 2009 04:02 PM
Pa150 Nate805 Chip Amps 1 14th November 2008 12:15 PM
They have arrived, PA150! CJ900RR Chip Amps 36 2nd September 2008 02:17 PM
Pre-DAC switching capability? Commited Digital Source 5 9th January 2006 05:29 PM
Page generated in 0.11008 seconds (82.04% PHP - 17.96% MySQL) with 10 queries
