LME49811 + Sanken STD03N/P - Page 3 - diyAudio
Old 3rd May 2009, 08:15 PM   #21
Dear Andrew,
We did measure the system with an audio precision ATS1, and there is no audible crossover distortion and THD and IMD are all below 0,008%
The bias for the STD03 N/P's is advised lower then average bij the Sanken application sheet
Official Sanken advice 40mA through both Re's.
So let's assume we stick to Sanken's datasheet and we use Re's of 0,22ohm and we want a current of 20mA through each Re we still have a voltage of 4,4mV across each Re (8,8mV total)
which is still lower then average. of course we can make it higher but then the Thermal tracking will work less precise.
In our first listening samples we sticked exact to the Sanken datasheet, means 40mA across both Re's
In that case for Re 0,1 we need 4mV. total across both Re's and for Re 0,22 we need 8,8mV
Just listening wise the 0,1 Re version with 4mV. sounds better then the 0,22 Re Version with 8,8mV. Both version where thermal stable.
For those who are interested, I attach the application sheet from sanken.
With best regards,
Bas
Old 3rd May 2009, 08:22 PM   #22
Dear,
Here a image of our prototype.
It is a 3 channel amplifier, with variable gain preamp section. 2x LME49810 + STD03 for mid and high, and BPA300 LM3886 for the subwoofer section.
In the final model I we consider to make the subwoofer amp also semi discrete with a bridged/parallel LME49810/STD03 combination.
Like Andrew point out many times on other sections on the Forum the heat dissipation of the LM3886 is a limitation, hence the fan on top of the heatsink
With best regards,
Bas
Old 4th May 2009, 09:18 AM   #23
Dxvideo is offline Dxvideo  Turkey
Dxvideo's Avatar
Send a message via Yahoo to Dxvideo
Dear Jack,
I have two pairs of SAP15 and some free samples of LME49811 in my drawer.. And I was planning to make a good amplifier with these devices for my living room...
So, do you think I can adaptate your inverted design to my SAPs? And have the same results as yours?
What about the input buffer? Do you use a preamp or buffer stage for this?
Best regards,
Ozgur
Old 4th May 2009, 11:55 AM   #24
jackinnj's Avatar
Originally posted by Dxvideo
Dear Jack,
I am trying to get it to remain thermally stable at a higher bias and much higher rail voltage, and would say that you're OK with a supply around 30V, but it gets more difficult with a 45V supply which is what I had planned to install them in.
FWIW, when I run the simple test circuit on the PDF, the THD% is down to the limits of my equipment (an AP SYS2022).
You might want to look at PansonHK's boards which are modular -- if you don't like the Sankens you can switch to TIP142/7's.
Why, silly hare, are you fleeing from the fierce jaws of the lion now grown tame?
Old 4th May 2009, 12:09 PM   #25
Dxvideo's Avatar
Dont you like its crossover distortion performance since youre looking for higher bias levels? In fact I was also not sure about to make this amp with SAPs, discrete darlingtons or lateral MOSFETs with gate drivers.. However without SAPs (or STDs in your application) Vbe multiplier will be needed.. Means a bit more complex layout.. In the other hand, SAPs (or STDs) provide a better thermal tracking as I heard..
Anyway, I planning to use this amp with 30+30 AC, not more than 42v DC per rail... So I can get 75W into 8R (and may be 150 per 4R) I think my SAP s will be enough for this power level (I will not use the on board resistors may be 0.1R external instead like yours)
I have tried TIP142/147 pair with my LM4702 amp (originally working with 2SK1058/2SJ162 pair) However MOSFETs sounded me (and still sounding) more musical.. TIPs sounded more bright I guess... But may be this situation is valid only with TIP series.. And may be SAP gives more natural sound..
By the way, have you compared inverted and non-inverted design by the meaning of sound quality?
Best regards,
Ozgur
Old 8th May 2009, 11:50 PM   #26
jackinnj's Avatar
I found that about 420R at R12 and the thing was thermally stable.
Old 9th May 2009, 12:56 AM   #27
Jack,
At this point are you happy with the circuit? Have you had a chance to listen to a stereo pair as of yet?
Best Regards,
Carl Huff
Old 9th May 2009, 03:13 AM   #28
jackinnj's Avatar
I have to mount them into their host (the Yamaha amplifier) but here's a graph of THD% vs Power at about 50mA of bias current:
Old 26th January 2010, 09:56 PM   #29
Dear jackinnj,
Any updates,
Dit you got the circuit stable?
With kind regards,
Bas
Old 20th February 2010, 01:18 PM   #30
vuthanh6's Avatar
Please update the final your circuit, Jackinnj. Thanks!
Thanh
Vietnam
Class A with LME49811... Dxvideo Chip Amps 22 2nd November 2009 02:11 PM
Sanken Output Transistors - STD03N/P - New! zener_diode Swap Meet 9 27th September 2009 04:06 PM
WTB: Sanken SAP15N & SAP15P (or STD03N & STD03P if compatible) dtm1962 Swap Meet 15 2nd May 2009 12:20 PM
LME49811 front-end for Gilmore amp? Artie Solid State 7 29th April 2009 09:36 PM
LME49810 with STD03N/P Sebastiaan Solid State 32 14th April 2009 09:47 AM
Copyright 1999-2017 diyAudio
