| Chip Amps Amplifiers based on integrated circuits |
Hi guys,
I want to make a smallish speaker system for me and my fellow dormies (No one has any decent speakers). And preferably on the cheap. I have experience soldering simple kits and today built the "champ" amplifier kit and regulated power supply quite quickly and without any hassle. The aims for the system is to be loud, as cheap as possible and durable. I've looked at suitable parts online for the system mostly at jaycar as other places cannot do not seem to be able to come close to their prices (perhaps this is an indication of quality?). Anyway here's what I've decided I want to build: 2x Studio Monitor type enclosures 1x Subwoofer So a 2.1 system. A diagram of the setup is below: ![]() Click for full size - Uploaded with plasq's Skitch Monitor contents (One monitor): 1x 8" Paper Cone Woofer @ $39.95 Each CW2196 http://www.jaycar.com.au/productView.asp?ID=CW2196 Impedance: 8 ohms Nominal Power: 90 WRMS 1x Piezo Horn Tweeter @ $29.95 Each CT1934 http://www.jaycar.com.au/productView.asp?ID=CT1934 Impedance: 8 ohms Nominal Power: ? Max Power: 400 WRMS 1x 2 Way Speaker Crossover 3.5Khz @ $12.50 Each CX2614 http://www.jaycar.com.au/productView.asp?ID=CX2614 Impedance: 8 ohms Nominal Power: 50 WRMS Cost per box: $82.40 Cost for two: $164.80 Potential Issues?: - Crossover not being able to handle the power from the amplifier. Is this fixable? - Building an enclosure? I'm not sure how to go about this. Are there pre-fabbed enclosures around? Subwoofer contents: 1x 12" Response Paper Cone Woofer @ $74.95 Each CW2199 http://jaycar.com.au/productView.asp?ID=CW2199 Impedance: 8 ohms Nominal Power: 225 WRMS Cost per sub box: $74.95 Speakers and Sub total: $239.75 + Enclosure + Wiring/Plugs Potential issues?: - Again the enclosure. I know sub woofer enclosures are available but they can be expensive. - Also, is it necessary to use a crossover so that the woofer is only sent a signal with frequencies within it's responsive range or is this not necessary? Next is the problem of amplification. The best solution seems to be a dual-mono (to achieve stereo) amplifier for the pair of monitors and then a separate amp for the sub. Contents of the Monitor Amp: 2x Ultra-Low Distortion 135WRMS Amplifier Module @ $94.95 Each KC5470 http://www.jaycar.com.au/productView.asp?ID=KC5470 135WRMS into 8 ohms (Using this as the speakers have an impedance of 8 ohms) 200WRMS into 4 ohms 2x Power Supply Kit for Ultra-LD Mk2 200W Amplifier @ $55.95 Each KC5471 http://www.jaycar.com.au/productView.asp?ID=KC5471 2x 40V-0-40V 300VA Toroidal Transformer @ $84.95 Each 1x 2 Unit ABS Black Rack Case @ $59.95 Each HB5150 http://jaycar.com.au/productView.asp?ID=HB5150 2x Diecast Heatsink @ $25 Each Cost of Amplifier: $581.65 + Connectors and Wiring Contents of the Sub Amp: 1x Studio 350 - High Power Amplifier @ $175.00 Each KC5372 http://www.jaycar.com.au/productView.asp?ID=KC5372 200WRMS into 8 ohms (Using this as the speakers have an impedance of 8 ohms) 135WRMS into 4 ohms 1x Power Supply 1x 70V-0-70V Toroidal Transformer 1x Diecast Heatsink @ $25.95 Each Cost of Amplifier: $200.95 + Toroidal Transformer + Power Supply + Connectors and Wiring Potential issues?: - I can't find an appropriate power supply or toroidal transformer for the Studio 350 Amp. - Cost. This is starting to add up. The speakers are affordable enough but the amps are jacking up the cost. Any input on this would be greatly appreciated. I'd like ways to cut the costs down and still stick to the original aims of being loud and durable. As this is my first project I am unsure as to if this is under or over kill. As I said before any and all feedback is welcome. |
#2 |
Hmm, decent and cheap only seldom go together. You could start with just two monitor style speakers and add a sub later if you need more "ooomph".
As a side note: I think there's a bit more to loudspeaker building than just making an enclosure and mount two drivers and a crossover into it... Have you been here? http://www.theloudspeakerkit.com For the novice diy-er a kit a great way to start. |
#3 |
You could certainly get away with much less amplifier power, even if you want it loud.
Have you considered to use a 2.0 setup? That would save the active subwoofer crossover and amplifier. A second of those 12" woofers plus crossover could be cheaper than that. Build the speakers and test them with your Champ. Then decide, if you need more SPL = power. If you do, look for Alesis or Behringer PA amplifiers. You should get them for less than 581 AU$ with all protection circuits on-board and waranty.
If you've always done it like that, then it's probably wrong. (Henry Ford) |
#4 |
Did you ever atttempt to build this amp?
#5 |
it will be cheaper to select higher sensitivity speakers/drivers and set your power targets appropriately lower.
eg. 86dB speakers and 300W or 90dB speakers and 120W or 94dB speakers and 48W all give about the same maximum SPL (about 105dB to 107dB at 2.5m listening distance). Don't bother with the separate woofer initially. Just build a pair of 94dB/W/m 8ohm two ways using 7inch to 9inch bass/mids with matching tweeters. Try using a 50W or 60W amplifier to drive these. If you do decide to add a separate bass speaker, then be prepared to be evicted from your dorm.
regards Andrew T. |
| Please advice me on this project | basstard | Multi-Way | 16 | 27th July 2008 01:22 PM |
| new project advice | slr 5000 | Multi-Way | 6 | 24th June 2008 10:27 PM |
| Would appreciate some advice on amp project | PJN | Solid State | 2 | 12th February 2008 05:52 PM |
| My DIY Project - Advice VERY Welcome! | ben_scammell | Multi-Way | 1 | 23rd September 2005 06:59 PM |
| New project - need advice, please. | conscious | Multi-Way | 0 | 2nd January 2005 08:21 PM |
| Page generated in 0.09777 seconds (79.57% PHP - 20.43% MySQL) with 10 queries |
