| Chip Amps Amplifiers based on integrated circuits |
#461 | |
Yes, I will make new universal power board for at least four pairs output devices. I did test for a separate rails for LME. Let me dig them out. Panson |
#462 |
I slightly modified the existing four-pair TT power board to have dual drivers (MJE15030/15031 x 2). Each driver pair drives two TT. Here is THD vs freq for 2.7 R, 4 R and 8 R loads. At 121 W into 2.7 R, THD is only 0.003 %.
#463 |
the extra drivers will allow a slightly increased gain from VAS to Output.
The extra drivers have reduced the current demand from the VAS. This is proof that a pre-driver stage is required when larger output currents are required.
regards Andrew T. |
#464 | |
It seems to me that the main advantage of multiple drivers is less current in each driver and so less distortion. JPV |
#465 |
the drivers as well as the outputs suffer gain droop at higher currents.
If the drivers only have to drive 2pair instead of 4pair of outputs then the driver gain will be higher and thus the VAS current into the bases of the drivers will be less. That is equivalent to saying the VAS sees a higher load impedance.
regards Andrew T. |
#466 |
Here is a plot for the low-level grounding wire placement. This wire connects power supply 0V and small-level signal section ground. The highest THD curve is obtained by placing that wire ~1 cm from output devices.
The other curves are associated with other wire placements with slight displacement with each other. With the best placement in the test, the THD at 20 kHz for 2.7 Ohm is 0.002 %! |
#467 |
Sometimes a square peg fits a round hole just fine
can NJL4302DG/NJL4281DG be dropped straight into your black universal boards given enough heatsink? I was going to grab some of both and try. and also, i'm pretty sure its a yes, but I can use the thermal track only 4 pair board with 2 pair to start and then add more later if needed right?
#469 |
thanks, OK I think thats sorted it. will use your amps for my bass channel will send an order in the next few days
#470 | |
you have been recently at a EMI Signal Integrity class haven't you ? I was, and boy what an eye opener it was. I am looking at a circuit board with a different set of eye' s now. Thanks for highlighting this very important yet often overlooked or better said neglected approach. Keep the loop area as small as possible and things magically fall into the right place ![]() panson_hk, great job, I am looking forward to the final version. Thanks for your awesome contribution DIYAUDIO forever Cheers Last edited by kct; 1st May 2011 at 07:57 PM. |
| 49830 tweaking | traw | Chip Amps | 0 | 3rd June 2009 04:35 AM |
| LME 49811 Project? | jaya000 | Chip Amps | 17 | 4th May 2009 01:01 PM |
| National LME 49811 | satanx | Chip Amps | 2 | 8th May 2008 11:29 PM |
| My differential input 49830 | Phil Olson | Solid State | 4 | 28th March 2008 06:20 AM |
| 3886x3 vs 49830 | Phil Olson | Chip Amps | 10 | 26th March 2008 06:59 PM |
| Page generated in 0.12192 seconds (79.72% PHP - 20.28% MySQL) with 11 queries |
