| Chip Amps Amplifiers based on integrated circuits |
Hi, i am new to here, i have a quite stupid question to ask, suppose i have a gainclone stereo amplifier with two LM3886, how i can split out and modify to install another mono LM3886 to sound up a subwoofer speaker. An easy way to say is, to make it 2.0 to 2.1.. can you guys show me any schmatics for me
thanksregards
#2 |
Just add 10K resistors to each channels line level output, then connect their other pins together. And from this junction put another 10K to the gorund.. Means make a Y shape with 10K resistors.. One branch to left channel, one branch to right channel and one to ground..
Then from the center point, connect your subwoofer..
Best regards, Ozgur |
#3 |
![]() actually i not really understand.. ~.~ why no need to add another extra amp on it example a LM4651/52? ~.~ by the way, my bronze BR2 show it's weakness on movie, i need certain ooohmmm when playing movie.. ![]() guide me out please ..
#4 |
use an inverting opamp as a summer amplifier. Each channel is fed in through it's own resistor. These meet at the opamp -IN input where the impedance is very low (virtual earth). Both signals add at this virtual earth and due to the very low impedance there is no crosstalk to the other channel. If the opamp is configured as a CFB filter then the one opamp becomes the summer and low pass filter and sends it's combined signal on to the power amp. If you are feeling very ambitious you can substitute the chipamp for the opamp and combine the whole shooting match into one chip. ps, DX has it all wrong.
regards Andrew T. |
#5 |
http://www.getelectron.com/subwoofer...amplifier.html
http://sound.westhost.com/project48.htm http://www.linkwitzlab.com/Pluto/subwoofer.htm
If you've always done it like that, then it's probably wrong. (Henry Ford) |
#6 |
Speakerholic
Simple.
Buy a plate amp for your woofer and use the speaker level inputs. The amp has a high pass for your satellites and the woofer XO is variable to match. Sound quality degradation is negligible. Done it many times. |
#7 |
http://tda1541a.com The Final List |
#8 |
now this look interesting
Is it just simply connct parallel with my gainclone to the signal output source? By the way i will use one dualchannel opamp indeed of two mono channel op. But i still, don't get the meaning of R3, R5, and R7? why it need to be attenuater? For R3, is it tone control? and thanks, you have help me a lot
#9 | |
Did you read my posting carefully? Is this wrong do you think?
#10 | |
to the sub amp and woofer.
| Right channel seems to have died on Kriesler stereo - need help | scientificexp | Solid State | 1 | 10th December 2006 07:38 AM |
| how to mix stereo into center channel | bob_v5 | Solid State | 0 | 14th February 2006 08:07 PM |
| Alternator Failed - Stereo AMP and SUB woofer cause ? | tommoran2 | Car Audio | 3 | 14th October 2004 11:59 PM |
| question for those using subs with 2 channel stereo | Jim85IROC | Subwoofers | 15 | 26th March 2004 02:38 PM |
| Page generated in 0.10446 seconds (79.28% PHP - 20.72% MySQL) with 11 queries |
