Quadruple Gainclone - yikes !
Old 8th May 2003, 03:53 AM   #11
davesaudio is offline davesaudio  Moldova
no ac ripple sneakin thru?
varta lviv
Old 10th May 2003, 12:17 AM   #12
jackinnj is offline jackinnj  United States
jackinnj's Avatar
Default i have the filters on
I mean the filters in the HP339a, the waveform itself looks fine, the supply which I am using is very low ripple (microvolts) and the setup is not conducive to ripple.
will check.
jack
Old 14th May 2003, 05:16 PM   #13
jackinnj's Avatar
Default ok, stupid me
I forgot to "unclick" the 400Hz filter -- with the filter out the THD is much more like the rest of the spectrum, and this isn't bad at all.
Quadruple Gainclone - yikes !Hide this!Advertise here!
FireWire speeds set to quadruple (to 3.2 GigaBit !) FastEddy Digital Source 0 18th December 2007 04:12 PM
Yikes, what are these cabinets? Glowbug Full Range 25 10th May 2007 09:25 PM
Yikes! DIY could be so much better (and cheaper) cheesehead Multi-Way 3 22nd November 2006 01:58 PM
Yikes! How did I end up here? rubix Introductions 2 21st June 2005 03:39 PM
Yikes!! FET Substitution? Could use some FET Guru's here... EchoWars Solid State 15 9th February 2004 07:08 PM
