Old 16th April 2009, 02:39 AM   #1
mudihan is offline mudihan  United States
Default Decoupling Cap across the postive and negative pins
This is regarding op amp bypassing. I have seen people putting a 0.1uf film/ceramic cap across the positive and negative power supply pins, instead of one cap to the ground for each of the pins. Why? And are there any advantages/disadvantages doing the former instead of the latter (besides saving a bit of money and slightly easier implementation)? Also, is there any point doing both?
Composing music>Playing Music>Listening to music>The equipments you use to listen to music
Old 16th April 2009, 09:28 AM   #2
Atilla is offline Atilla  Norway
Soldering Gun Fanatic
http://www.designers-guide.org/Design/bypassing.pdf
This link could give you a little more detailed info about where and how caps are being placed and the desired effect on the circuit in mind.
Old 16th April 2009, 11:02 AM   #3
some opamps have one cap from V+ to V- and a second cap from Ground to one Vsupply. The data is usually in the datasheet.
It depends very much on how the internal connections are run inside the IC.
regards Andrew T.
Old 16th April 2009, 06:26 PM   #4
Thanks. I thought that it's another kind of general approach.
Old 17th April 2009, 11:46 AM   #5
Which opamps have a direct path from positive to negative supply, so that they'll require a bypass directly rail-to-rail?
Old 17th April 2009, 12:29 PM   #6
If I understand your question correctly then I'd suggest that all opamps have this direct path since none have a ground with the 8pins normally available.
regards Andrew T.
Old 17th April 2009, 12:50 PM   #7
Hm, I didnt word this correctly at all. Of course, most opamps don't even have a ground pin.
I mean that in the usual Class AB amplification, current flows go from one rail to ground, at a time, which is the path you'd want to bypass, thus having bypass caps from each rail to ground, to assist you with short high-current demand. In such an application, how does a bypass between the rails help, I'm not sure I'm getting it right?
Which terminal is postive ? Jan Dupont Multi-Way 23 14th March 2007 08:35 PM
Spray-on postive resist (Positiv 20) in US? gmikol Parts 6 10th November 2006 11:34 AM
Manipulating TDA1541 via decoupling pins Bernhard Digital Source 0 7th April 2004 08:49 PM
Voltage on TDA1541´s decoupling pins... weissi Digital Source 4 14th January 2004 07:34 PM
lm pins theChris Chip Amps 0 26th April 2003 10:32 PM
Page generated in 0.08364 seconds (76.10% PHP - 23.90% MySQL) with 10 queries
