TDA7386 Problem
TDA7386 Problem
Old 14th April 2009, 09:24 PM   #1
jorge_rc is offline jorge_rc  Portugal
Default TDA7386 Problem
I try to build the circuit using the TDA7386. I tought I had recriated the schematic provided on datasheet, but ir didnt work...
I let the for you to can help me.
Please Help me
Old 14th April 2009, 09:51 PM   #2
mjf is offline mjf  Austria
hello.
i think you have reverted tab and svr - tab goes to ground and svr needs the elcap..................
greetings.....
Old 14th April 2009, 09:54 PM   #3
pacificblue is offline pacificblue  Germany
At first glance it seems that the 47 µF capacitor is at the wrong pin. It should be connected to pin 10, but you connected it to pin 25.
If you've always done it like that, then it's probably wrong. (Henry Ford)
Old 14th April 2009, 10:02 PM   #4
Originally posted by mjf
hello.
greetings.....
Thanks.. but is that enough to make the circuit not to work???
Thanks again
Old 15th April 2009, 07:32 AM   #5
Yes, because the SVR pin controls the on/off delay. It is charged through the TDA, and the amplifier turns on, when the capacitor is charged to a certain voltage. If you force that pin to ground, the amplifier will remain off.
Old 15th April 2009, 07:39 AM   #6
OK. Thanks a lot....
And what about mute and stby?
thanks
Old 15th April 2009, 07:32 PM   #7
Mute and Standby should turn on after the amplifier. The datasheet application you are using is surely designed accordingly.
TDA7386 ProblemHide this!Advertise here!
Help with TDA7386 jorge_rc Chip Amps 8 20th June 2012 08:46 PM
TDA7386 Car Amp Redshift187 Chip Amps 21 26th May 2009 01:13 AM
TDA7386 Problem please help Brownstocker Chip Amps 5 28th January 2008 11:02 PM
Tda7386 koloko Chip Amps 1 18th June 2007 09:25 AM
Problem with TDA7386 SideWinder Chip Amps 0 24th May 2004 11:13 AM
Copyright ©1999-2017 diyAudio
