questions about gainclones
Old 24th April 2003, 02:00 PM   #1
Matttcattt is offline Matttcattt  England
Matttcattt's Avatar
Default questions about gainclones
i want to try bridging and parrelleling gainclones, which should i try first and what circuit/s should i use?
what chips should i use when bridging?
in theory can the input capacitor be any value? maplin have some nice 8uf ones for 5 and 15uf for 10
i am ordering some chips: OPA548T, OPA541AM, OPA541AP, OPA549S and OPA549T, what other chips should i try (not just the gainclone chip itself, balancing ones for bridging)?
i ordered some OPA549 from Texas Instroments a while ago (a month+) and i havent recieved them, are they really being bought up that fast that they stay out of stock?
If it aint broke, don't fix it. If it is broke, fix it.
If you can't fix it, take it apart and see how it "worked".
Old 24th April 2003, 02:27 PM   #2
Emilio is offline Emilio  Spain
Talking NSC BPA-200
Hello,
Regarding the circuit and parts list, you should read National Semiconductor Application Note BPA-200 in http://www.national.com/appinfo/audi...ation_Note.pdf
It has everything you wanted to know but were afraid to ask...
Emilio
Old 24th April 2003, 03:51 PM   #3
Matttcattt's Avatar
is this the simplest circuit for bridging and parelleling? are the 1kR input resistors necesary? are the 0.1R resistors between the outputs and the speaker necesary? is the LF412CP the correct opamp for U5?
Old 24th April 2003, 03:54 PM   #4
Matttcattt's Avatar
my power supply that i am building is using this circuit, is there any need to use the circuit in my next post for a gainclone? i am no audiophile
Old 24th April 2003, 03:59 PM   #5
Matttcattt's Avatar
Old 27th April 2003, 08:57 PM   #6
Matttcattt's Avatar
answers to my questions?
Old 30th April 2003, 05:01 PM   #7
Matttcattt's Avatar
i really would like some answers, or atleast comments
Old 30th April 2003, 05:09 PM   #8
rtirion is offline rtirion
Resistors are necesary. U5 can be any unity gain stable opamp.
(make sure it is)
Second supply looks better. It's got some nice bleeders.
It also has snubbing caps around the bridge which help little.
Old 30th April 2003, 05:11 PM   #9
crown300 is offline crown300
I'll bite..............
The 5k resistors are to bleed the 33KuF caps when the Mains power is shut Off - this would be a "normal" type of safety precaution.
22nf - There has been a very good input by a person whose name I forgot (Please excuse me for that) about "Snubber" caps and how their use may actually make it worse. I wouldn't use them, although I WOULD use a MUR or other Fast/Soft rectifier Diode.
If you just want to try it, you just have to build it. Then make ONE change at a time to see if you like it better.
johnm
Old 30th April 2003, 07:34 PM   #10
Matttcattt's Avatar
thanks for the answers
are the 0.1R resistors really necessary? what do they do?
questions about gainclonesHide this!Advertise here!
My Gainclones cadbike Chip Amps 6 10th November 2005 03:47 PM
Gainclones in car amp mmmax Car Audio 15 1st November 2005 06:16 PM
Big Gainclones Ropie Chip Amps 4 12th July 2004 05:30 PM
Several Questions about the LM4780 GainClones geewhizbang Chip Amps 14 15th June 2004 08:18 PM
Tell me about gainclones Solid Snake Solid State 46 16th November 2003 10:59 PM
