questions about gainclones - Page 3 - diyAudio
Old 2nd May 2003, 04:05 PM   #21
Matttcattt's Avatar
how can i measure the current my gainclone needs? if i connect my multimeter in series with one of the power rails, i get zero reading and severe distortion on the output.
If it aint broke, don't fix it. If it is broke, fix it.
If you can't fix it, take it apart and see how it "worked".
Old 2nd May 2003, 04:21 PM   #22
Banned
Talking Truck
Originally posted by Matttcattt
its going to be a car amp max voltage is about +/- 14v, i cant aford more batteries.
it doesnt need that big a power supply does it?
my 2 channel gainclone with a +/-12v supply takes about 2A max, which is about 12VA needed? 12x8=96VA. or am i insane?
at 60watts per chip at 24v is 2.5A max, 2.5x16=40A.
re-thinking needed possibly
maybe i could aford +/-24v supplys
edit: i have 66,000uf on each rail
12Vx2A = 24 VA.
Anyway, you need big batteries, and worst than that, how are you going to charge that?
The alternator on your car may not handle with that.
Maby you could go with a switching PSU instead of batteries.
You're confusing me!
Old 2nd May 2003, 05:20 PM   #23
Matttcattt's Avatar
its not 12v, its +/-12v, 24v total
Old 2nd May 2003, 08:08 PM   #24
JAZZ2250's Avatar
I also tried to measure the current exactly the same way as you tried, and had hudreds of mA reading on multimeter. Of course I had SEVERE distortion on the output. There should be some other ways to measure it. Any comment, please?
Old 2nd May 2003, 08:30 PM   #25
Matttcattt's Avatar
are the capacitors circled in red electrolytic? can i use electrolytic capacitors? can i use 1000uf ones? i have loads. i am using 4 on one circuit board, can i use one 1000uf capacitor per rail for all of them?
where do the input capacitors go? after the potentiometer? where the blue circles are?
Old 5th May 2003, 08:20 AM   #26
Banned
Red face waste of parts and time
Matttcattt,
Something has hit me in my had, I was too confused.
Have you read the datasheet of the LM3875?
With +/-12 volts you get something around 10 watts.
If you bridge two of them, you get 20 watts.
Paralleling you double the current.
So... with 4 chips in bridge-parallel configuration per channel you'll get 20 watts!
It's a big waste of parts, time and money.
These power op-amps are not made to work at these low voltages.
You should investigate the TDA1562.
You'll get around 3 times more power with one chip per channel than with four LM3875s in bridge-parallel at +/-12v.
And it's made to work on single voltage supply.
For these voltages I don't know a chip with more power than this.
It was made for car-audio.
Old 5th May 2003, 09:49 AM   #27
Carlos,
Your power calculation isn't quite right: when bridging an amp the power theoretically increases by x4 since power = V^2/R
Single ended, assuming an 8R load and +/- 9v output swing....
9v^2 / 8 = 10 watts
As above but bridged to give a +/- 18v output swing....
18^2 / 8 = 40 watts.
When bridging an amp, the output current doubles compared with the single configuration. In the case of the bridged amp above, the peak current is 18v / 8R = 2.25A, which is well within the capabilities of a single pair of LM3886 devices so paralleling isn't necessary.
Bridging is an efficient way of getting high power from low supply voltages.
David.
Old 5th May 2003, 10:11 AM   #28
Banned
Talking Right
David,
You're absolutely right, now I wake up...
But I still think it's much cheaper to use 4 TDA1562s (only one per channel).
Or else it's going to be a huge amp, and the man will loose all the baggage space of his car with the amp and the extra batteries.
And to charge those batteries...
I think he wants a Krell in his car.
Old 5th May 2003, 10:11 AM   #29
Matttcattt's Avatar
Default Re: waste of parts and time
Originally posted by carlosfm
Matttcattt,
parts: chips, free, others about 1 per amp (about 16)
time: i have loads of time
money: as above
im using the OPA541, not the LM3875. it can run with +/-4v.
Old 5th May 2003, 10:16 AM   #30
Matttcattt's Avatar
for the third time :
My Gainclones cadbike Chip Amps 6 10th November 2005 03:47 PM
Gainclones in car amp mmmax Car Audio 15 1st November 2005 06:16 PM
Big Gainclones Ropie Chip Amps 4 12th July 2004 05:30 PM
Several Questions about the LM4780 GainClones geewhizbang Chip Amps 14 15th June 2004 08:18 PM
Tell me about gainclones Solid Snake Solid State 46 16th November 2003 10:59 PM
Copyright 1999-2017 diyAudio
