| Chip Amps Amplifiers based on integrated circuits |
#41 | ||
But you're not going to get your 4 volts with just a few turns of wire. The voltage you get on the secondary is a function of the voltage across the primary and the turns ratio betwen the primary and secondary windings. So let's say you have 120 volts on your primary. To get 4 volts on the secondary with only 6 turns would mean your primary would have to have (120/4) x 6 or 180 turns. Any low frequency (50-60 Hz) power transformer is going to have quite a few more than 180 turns on its primary. Of course this is idealized and doesn't account for core losses and other realworld things that get in the way of the ideal but you get the picture. What's the big deal about powering LEDs this way anyway? se |
#42 |
Power incicators and such. I have used this technique for a year or so. Never actually measured the output of the windings, just did it on a recommendation a while back. Then I got a bunch of power switches for free but the had built in LEDs not incandesant bulbs. I tried used the same trick on my gainclone a few months back when I used one of them. I will try a few experiments when I get home though and make sure I fully understand the technique. Thanks.
Philip "If you didn't make it with your own two hands, its not really yours". |
#43 | |
For purist, it's isolating LED from rails, which never hurts. Some people claim that LEDs have effect on sonics, so this is to keep those folks happy Some people don't know which rail to choose, so this solves their problem as well (some actually connect two LEDs, to keep rails balanced)![]() I tried that trick, and believe me, I didn't need more than 10 turns to activate blue LED, which usually needs more voltage than red one. And transformer was fine too ![]() In my current PS, i just don't install LEDs at all. Who needs them, if the amp is on all the time anyway?
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#44 | ||||
![]() Quote:
Or wear your hairshirt proudly and stop your whining. ![]() Quote:
![]() In the words of the Guess Who (though I like Lenny Kravitz's cover better), "colored lights can hypnotize. Sparkle someone else's eyes." se |
#45 | |
#46 | |
But yeah, the best solution is no LEDs to begin with. se |
#47 | |
Banned
#48 | |
Have you seen the nixie digital clocks that are being sold now? se |
#49 |
Banned
Yes, sure. But a friend of mine has a (unicat) Nixie- clock for more than 15 years, the tubes are about 200 mm high!
a very very freaky solution for CDP display would be decatrons. An other friend of mine has in his garage some dozend small nixies from calculators... Maybe some day i find time i will use them with a mikrocontroller. If i find someone who writes the DSA output code. |
| Gainclone: 2 newbie questions... | Bassterror | Chip Amps | 10 | 3rd April 2006 02:23 AM |
| Parallel gainclone questions | ejn327 | Chip Amps | 6 | 6th January 2005 05:28 PM |
| Questions on gainclone powering a sub | mFinalHeaven | Chip Amps | 6 | 17th August 2003 07:59 AM |
| very simple gainclone questions | wrl | Chip Amps | 4 | 23rd June 2003 07:01 AM |
| Gainclone questions | trespasser_guy | Chip Amps | 47 | 24th April 2003 01:02 PM |
