Old 8th April 2009, 03:20 PM   #1
Jim Shearer's Avatar
Default T-amp compatability w/ sub plate amp
OK, please forgive me if I ask a question that you have answered a thousand times, but I can't seem to locate what I want to know w/ the search function. And I don't know enough about electronics to figure it out myself.
I understand that you can't hook up a Sonic Impact t-amp to a subwoofer plate amp via speaker wires due to the lack of a common ground in the t-amp.
I can see that the neg speaker leads should not be connected, as in hooking up both channels to a plate amp. However, is there a problem w/ connecting only ONE channel to the plate amp by speaker wire? Is the 'floating ground(?)' of the t-amp output not compatible w/ the (I assume) grounded input of the plate amp?
Thanks for your help (and patience.)
Jim
A day without music is like a day without food.
Old 8th April 2009, 06:34 PM   #2
The Sonic Impact is a bridged amplifier. That means all speaker terminals are 'hot' and connecting either of them to ground would be a short-circuit.
You could use RCA-Y-adapters and split the input signal before the T-Amp.
If you've always done it like that, then it's probably wrong. (Henry Ford)
Old 8th April 2009, 08:12 PM   #3
Very interesting! I guess if I want to use a T-amp, I will need to build a passive pre-amp.
Thanks much for the info!
Jim
Old 8th April 2009, 09:06 PM   #4
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
Is the plate amp class-D? If it is AB you probably won't get very good results.
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Old 8th April 2009, 10:33 PM   #5
amt is offline amt  United States
You can build a "magicBox" for next to nothing and see what you think.
I built one and is seems to work okay.
http://www.audiocircle.com/circles/i...&topic=38384.0
Audiomagus sells something similar but more sophisticated if you dont want to build one. Maybe Panomanic will pop in to 'splain the performance difference.
http://www.audio-magus.com/SubLine_S...tor_p/slv2.htm
amt
Old 9th April 2009, 03:05 PM   #6
amt,
Thanks! I don't think I want to spend as much for an interface to the sub amp as I spend on the T-amp, but the Magic Box looks easy enough.
Nuuk,
I'm unclear on what you mean. I've used a passive sub in the past, but have found using a plate amp much better--easy to integrate w/ the mains. And I only want the subs to go up to about 40 Hz. Can't say that the cheap class D amps have any audible issues below 50 Hz.
Cheers, Jim
Old 9th April 2009, 03:16 PM   #7
Nuuk's Avatar
It's the issue with class-T Jim where phase changes with frequency. This can make it had to integrate a class-T with a class-AB amp used in the same system.
I have both AB and class-T amps that I can use for my woofers but if I mix either of them with another class of amp, it just doesn't sound 'right'! (I cross over at 60 hz)
Old 10th April 2009, 04:34 PM   #8
Interesting. Thanks for the advice.
Jim
Old 12th January 2010, 09:41 PM   #9
gurley123's Avatar
Sorry to dig up an old thread but does anybody have a copy of Ed's "Magic Box" diagram? The forum it was in is shut down and I forgot the particulars of it. Any help would be appreciated.
Pot and knob compatability AmpBuilder225 Tubes / Valves 4 25th February 2009 06:45 PM
adjustable voltage regs compatability KevinLee Parts 1 16th December 2008 07:18 PM
Amp / Driver Compatability patherb Multi-Way 12 13th June 2008 04:36 PM
Page generated in 0.09733 seconds (78.39% PHP - 21.61% MySQL) with 10 queries
