Old 7th April 2009, 07:44 PM   #1
Default Grounding chipamp 3875
I need help with connecting my chipamp-kit, LM3875. The problem i have is that my volume pot is not working. On no volume, i still hear normal level and if i raise volume it goes up very quickly.
I have a chipamp.com kit with a CT Transformer. I have enclosed a quick drawing of my setup. Since i have a wodden chassi, i have serial connected all input rca grounds and runs them pass the rotary switch directly to SG.
Any help for a newbie?
Please excuse my simple drawing...
Old 8th April 2009, 10:47 AM   #2
I need more info.
can you colour or or identify the signal lines differently from the return lines?
Can you add on the other ground/return lines connected to the amp PCB?
Can you confirm how you have connected the pot/attenuator?
Is chipamp an inverting topology?
Can you link to a schematic?
regards Andrew T.
Old 9th April 2009, 08:42 PM   #3
The problem is that my volume pot (50k log) is measuring 14k when fully turned to zero. So i still here music.
The ground from pot goes to SG on PCB, same as input gnd.
I dont have schematic for Audiosector kit.
Old 9th April 2009, 10:34 PM   #4
50k becomes 14k at zero position? Either the potentiometer is broken or you connected it in parellel to the 20k input resistor and the wrong way round.
Here is your schematic. How can you build an amplifier without a schematic?
If you've always done it like that, then it's probably wrong. (Henry Ford)
Old 9th April 2009, 11:31 PM   #5
Default NIGC = DC coupled
A newbie should not be building a DC coupled amplifier.
Be very careful you don't burn out your speakers.
regards Andrew T.
Old 9th April 2009, 11:45 PM   #6
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
Your basic schematic seems to be fine. Why don't you look through this thread: http://www.diyaudio.com/forums/showt...97#post1516297 Everything has been explained there.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 10th April 2009, 01:16 PM   #7
ratza is offline ratza  Romania
ratza's Avatar
Linear pot, maybe?
Any solution is a compromise.
Old 10th April 2009, 07:27 PM   #8
The pot is fine, it measures fine when disconnected.
The main thing i supspect is the grounding of the amp boards.
Peter - when using a centertapped transformer, the centertap goes to PG+, Then i only have 2 PG- and one PG+ left. Should i only use one PG+ per board and thats it?
Old 10th April 2009, 08:13 PM   #9
With CT transformer you need to modify the bridges; it's been explained here: http://www.diyaudio.com/forums/showt...83#post1196283
www.audiosector.com
Old 10th April 2009, 10:10 PM   #10
Originally posted by pacificblue
you connected it in parallel to the 20k input resistor and the wrong way round.
50k || 20k = 14,3k
Desolder the 20k input resistor and check again. If it works, replace the potentiometer with a 20-25k type for better CMRR.
FS chipamp 3386, 3875, 1 enclosure wendell Swap Meet 4 15th June 2008 03:06 PM
Dual-mono chipamp (3886) problem - possible grounding issue phresh Chip Amps 31 29th February 2008 03:50 PM
Preventing a 3875 chipamp from blowing tweeters bcdzt5 Chip Amps 8 6th February 2008 07:23 PM
Recommended UK transformer for 3875 chipamp? Colin Chip Amps 6 1st March 2007 08:02 PM
Chipamp.com pcb with linkwitz 3875 design akunec Chip Amps 3 7th June 2005 07:06 PM
Page generated in 0.10484 seconds (77.92% PHP - 22.08% MySQL) with 11 queries
