Old 6th April 2009, 03:18 PM   #1
bm0rg is offline bm0rg  United Kingdom
bm0rg's Avatar
Send a message via MSN to bm0rg
Default BPA200 / Stereo Bi-wire PCB V1
Hi all,
Just finished laying out this board. Its based on National Semiconductors bridge/parrallel amplifier schematic (figure 13) from the document http://www.national.com/an/AN/AN-1192.pdf.
Id very much like some feed back and people to check I havent made any mistakes before I send it to be made.
Parts match that on page 18 of the AN-1192 document
Configurations options of the board:
BPA 200 with servos
BPA 200 without servos
4 single LM3886 (stereo bi-wire) 4 seperate ins and outs
Attached should be a PDF of the top + bottom + silk
Thanks for looking
Old 6th April 2009, 04:40 PM   #2
bm0rg's Avatar
Top layer and silk.
Old 6th April 2009, 05:19 PM   #3
bm0rg's Avatar
Bottom layer and silk
Old 6th April 2009, 08:35 PM   #4
Looks, as if you had skipped a bunch of capacitors. There only seems to be one of the eight 100 nF decoupling caps (Cby2) on the board. The missing ones can still be soldered directly to the IC pins, but where do the 470 µF (Cby5) go? The two 3300 µF capacitors on board are not replacing the eight 10000 µF capacitors recommended off board in the application note, are they?
Four separate muting circuits can lead to strange behaviour at the speaker terminals. The capacitor tolerances will lead to unsynchronized activation of the four amplifier channels. One Rm/Cm combination that acts on all channels would be better.
There seem to be three missing connections. RF4 to its corresponding output, RD1 to CD1 and Rb3 to CB2.
If you've always done it like that, then it's probably wrong. (Henry Ford)
Old 7th April 2009, 04:16 AM   #5
sasmit is offline sasmit  India
Send a message via Yahoo to sasmit
isolation for the ground polygon is too small, you need to increase the isolation(clearance between components not connected to ground and ground plane ). PCB maker might not be able to work with this much tolerance.
IMHO ground plane type design is not preferred especially for high power amp designs...national mentions the same on their application note on LM4702 based power amp design.
Old 7th April 2009, 03:55 PM   #6
bm0rg's Avatar
Thanks for the feedback pacificblue and sasmit! Much appreciated.
I have so far corrected:
The 7 missing CBY2
Removed 3 of the muting circuits and join U1,U2,U3,U4 to a single muting circuit I guess the values will now be quiet different? Each chip needs to draw 0.5 mA so all 4 together will 2mA right?
Sorted the three missing connections.
Having done that this just leaves the 470uf caps and ground plane.
These two issues require a major redesign i.e. a bigger board to accommodate 8 470uf (12mm in diameter the smallest I could find for 50V) in there various places close the IC would be best I guess?
The 3300uf were just there as extra to make up for the 2 73800uf supplies in my 2 BA100 amps. I was going to use one per channel for the BPA200 this should be enough. Do I need the extra 3300uF? I guess 8 470uF close to the pins would be better than 2 3300uF?
Thanks again guys for the help.
Attached a pic of the current supplies for those interested
Old 7th April 2009, 06:28 PM   #7
Right.
Absolutely.
Old 8th April 2009, 08:41 AM   #8
bm0rg's Avatar
Default PCB V2
Ok here is V2 with the corrections. The layout is a little different and some how ended up being a little smaller.
CBY5 and CBY2 are all as close to the pins as I could get them.
For the muting circuit if I have a power supply of +/- 36 v dc which if I calculated correctly Rm should equal 16700 ohms so I guess a 16k or 15k resistor?
Cm I believe softens to mute on/off. 100uF ok?
Thanks every one for the help so far.
Old 8th April 2009, 08:50 AM   #9
bm0rg's Avatar
And the top layer
Old 8th April 2009, 08:56 AM   #10
bm0rg's Avatar
And the bottom
Max voltage for bpa200 enter Chip Amps 29 18th February 2006 11:54 PM
Bpa200 enter Chip Amps 2 3rd January 2006 08:16 PM
How to wire up an Alps 100k Stereo Pot? ble0t Chip Amps 2 24th May 2004 03:32 AM
My BPA200 PCB Dxvideo Chip Amps 14 11th December 2003 07:25 AM
How do I wire stereo headphones on a stereo tv? hike1 Everything Else 2 10th September 2001 02:22 AM
Page generated in 0.10606 seconds (80.60% PHP - 19.40% MySQL) with 11 queries
