| Chip Amps Amplifiers based on integrated circuits |
hello Everybody ,
I want to make the TDA7293 amplifier , but I don't find a PCB for do the typon ! Unfortunately, on the datasheet , there isn't the PCB of the Simple montage Do you have it ? Thnaks for all |
#2 |
Are you looking for a layout to make your own PCB?
http://www.jeanyvesmartin.com/schema...a-7294-a5.html Or for a PCB to buy? http://www.diy-selbstbau.de/produkte/a80-en.htm Did you try the search button?
If you've always done it like that, then it's probably wrong. (Henry Ford) |
#3 |
I used the PCB in the datasheet and it worked fine and was an easy to make and etch PCB... I have a ready to etch Image of this PCB design if you want it ....
If you look on e-bay you can buy a stereo TDA7293 Kit with all Parts and PCB for about $23 US which is about the price of just the two TDA7293 chips.... Cheers |
#4 |
I think, jbdivx did not like the layout in the datasheet, because he prefers the TDA next to the PCB edge for easy mounting to a heatsink.
#5 |
Thnaks for your help !
i find the kit on Ebay : http://cgi.ebay.com/TDA7293-Hi-Fi-Po...hippingPayment On the photo , we can see a " stereo model " , but in the description it's not mentioned, so I well send a mail to the seller. On this kit , probably , this isn't the best components (MKP, ceremaiq resistor same Vishay ) So probably , i will buy the kit and modify some components + |
#6 |
Hi ,Yes it is a stereo model but can also be wired in Bridge mode or Paralell for mono, the Kit comes with instructions on how to do this .....
That is the same one I just bought , it hasn"t come yet though... I also bought the power supply board which was $6 and comes with the bridge rectifier and terminal blocks and some smaller value caps and a couple resistors (Snubber ?) but doesn"t come with the big PSU Caps but still a damn good deal for $6 ..... His kits are the least expensive out of all the kits I have looked at I just hope they aren"t cheap.... Cheers |
#7 |
Hi see the schematic
you can find on ebay works better with a 6922 in cathode follower on input ![]() to build a perfect hybrid
visit my audio website www.esafono.it |
#8 |
Interesting... I may give it a try...
Fiat bagus!4,700uF x 63V Caps for Sale - $1.25 each - CLICK HERE FOR COMPLETE PRICING INFORMATION |
#9 |
| need help with TDA7293 | weatherlight | Chip Amps | 19 | 20th June 2008 01:55 PM |
| Tda7293 | lasstss | Chip Amps | 2 | 14th December 2004 05:36 AM |
| Where can I get a TDA7293??? | mfish0305 | Solid State | 2 | 18th January 2004 04:19 AM |
| My TDA7293 project... please help | JojoD818 | Chip Amps | 3 | 28th November 2003 03:02 AM |
| Tda7293 | chengtaw | Solid State | 0 | 18th April 2002 02:19 PM |
| Page generated in 0.09948 seconds (81.61% PHP - 18.39% MySQL) with 11 queries |
