| Chip Amps Amplifiers based on integrated circuits |
Hi guys,
I've build a speaker for my notebook using three TDA2030's. With one amp connected to the PSU the sound quality is very good, but the quality drops as I connect other two amps to the PSU. It gets hum...noise. Could you plaese guide me how to wire multiple TDA2030 amp boards to a single power supply? Thank you in advance, Stinger |
#2 |
What current capacity is your power supply?
#3 | |
#4 |
Sounds like something isnt wired correctly.
Do you have a circuit diagram? |
#5 |
do the other two amps work if you just connect them individually?
Dave |
#6 |
I don't have any at the moment. But I will draw one asap I can in a few days.
regards! Strynger |
#7 | |
#8 |
As you see each amp has two grounds. one is for signal-gnd and the other is for decoupler and bypass capacitors.
Where's the problem with my wiring? I have another question about the diode pole; Can they cause any problem? |
#9 |
#10 |
no picture there...
| Focusing on wiring cable for gainclone!!!Share ur experience in wiring cable.... | thomgun_lc | Chip Amps | 38 | 31st August 2005 02:46 PM |
| I'm wiring my 4 channel 8 parallel LM4780 boards... check my wiring :) | Audiophilenoob | Chip Amps | 9 | 16th August 2005 04:37 AM |
| pro amplifiers vs. home audio amplifiers | bonsai171 | Solid State | 26 | 25th February 2004 08:24 PM |
| Paradigm amplifiers? Anthem amplifiers? | Corn-Picker | Solid State | 2 | 24th January 2004 03:10 AM |
| Many smaller amplifiers vs. bigger amplifiers. | djdan | Solid State | 9 | 17th September 2002 04:40 PM |
| Page generated in 0.10185 seconds (80.51% PHP - 19.49% MySQL) with 11 queries |
