Old 31st March 2009, 07:41 AM   #1
ThomasR is offline ThomasR  Belgium
Default another BR100; advice please
Hello everybody,
This is the beginning of my next project; i maybe shouldnt work on two at the same time, but the XregVSPS- double mono pcb is finished, and i only have to get it made and assembled.
i based this scheme on the application guide from NS itself, combined with the second scheme on this page.
Lm3886 Bridged Problem
since i'm only just starting pcb design, i'd appreciate it if you could give it a look.
because i would like to keep it single side, there are some bridge points,
but i tried to keep the feedback resistors on the pins, and the signal paths as short as possible.
a few things i'm not entirely happy with is the ground path and i probably overdid it a little on the filter caps.
I might remove two of the big ones, and put them in front of the psu.
As a PSU i'm thinking of a LM338 regulated one probably around 26v. (8ohm speakers)
I'll be building it double mono as a power amp, since i've got a tube preamp coming.
for the signal caps i'm thinking of auricaps or other HQ stuff.
what do you guys think? is it any good? comments, even negative ones highly appreciated.
(but please a little more than "its cr*p )
thanks,
Thomas
ps: currently working on understanding the input impendance thing, wich i heard can be an issue with this design.
Old 31st March 2009, 03:47 PM   #2
being ill, i have some time to work on this
i like the layout of this one better, but i'm a bit concerned regarding the length of the signal path on the bottom and right hand side.
also it has smaller caps, snubbers 'll go on the pins.
any input?
greets,
Thomas
Old 22nd July 2010, 12:40 PM   #3
neeraj is offline neeraj  India
have you made it or try it.
how doest it works?
Post some pics of completed amp.
Neeraj
Searching for a PCB for a BR100 - Bridged LM3886 seebaer Chip Amps 5 11th August 2011 06:22 PM
My LM3886 Board Based On BR100 Schematic gcds Chip Amps 3 8th January 2009 09:08 PM
BR100 Design Correct? Cadaver Chip Amps 3 20th July 2007 06:22 PM
Poster in Musical Instrument forum needs bridging advice on BrianGT 4780 advice moving_electron Chip Amps 0 16th February 2005 12:37 AM
BR100 Feedback Resistor / Rf1 and Rf2 not equal? Hybrid fourdoor Chip Amps 1 19th September 2003 09:37 AM
Page generated in 0.08179 seconds (73.15% PHP - 26.85% MySQL) with 11 queries
