| Chip Amps Amplifiers based on integrated circuits |
Hi everybody , i'm sorry , i'am french
![]() I have a toroidal transfomer 500VA 2x37V I will go to do an amplifier with TDA7293 or LM3875, LM3886... But i have a problem : 37V * 1.41 = 50V approximatively So, i need to reduce voltage of about 15V for supply a LM3875 for example. So , can i use a regulator same the LM338T for reduce the voltage ? http://www.datasheetcatalog.org/data...a0g60wc4wy.pdf Is that using such a regulator can degrade the signal output of the amplifier and therefore have a sound worse ? Sorry for my poor , bad , low , English.....
#2 |
No need to be sorry for being French.
![]() The following link seems to be just, what you are looking for. http://www.romanblack.com/gainamp.htm
If you've always done it like that, then it's probably wrong. (Henry Ford) |
#3 |
I am actually in the process of using a LT1084 (or LT1083) regulator
i will hopefully post my results as soon as i get the remaining parts in... Dave |
#4 |
Thanks for you help
I just saw the page, but I have a problem , the assembly is too difficult for me ( utilisation of a PNP transistor ) I juste want , if it is possible to find a transistor which can do the job I finded the LM350 (3A max) and the LM338 (5A max) but both of them , when Vin - Vout = approximatively 20 V have a fall of Iout So my idea is of take 2 x LM350 in parallel (it is already difficult for me) So , do you think , it 's a good idea ? |
#5 |
paralelling requlators by simply connecting them in paralell won't work..if thats what you're thinking
.. LM338 data sheet has many schematics on how to build a high current psu with multiple regulators.If you're dropping too much voltage across the regulator you'll not be able to achieve the maximum current capacity of the regulator. If you're just gonna run 2*LM3886 .. 1 LM338 ( one per rail ) will be upto the job...but might run a bit warmer than usual. As regards sound quality there won't be muh difference, if your supply is adequately sized. |
#6 |
is another transformer out of the question ?
#7 |
I don't have other transfomer .....
sasmit, I want to use LM350 - 3-Amp Adjustable Regulator http://www.national.com/mpf/LM/LM350.html But , 2X LM350 for each canal ! in parralel....Moreover , if i use a regulator , i must do this installation : SoftStart => Transformer toroidal => Diode Bridge => Capacitor (1x15000uF) => Regulator => Capacitor (1x15000uF) => Capacitor MKP I have only capacitor of 15000uF 63v at house ( I have 8 capacitors ) 30 000uF for each canal for a TDA or a LM3875 is enough sufficient ? |
#8 |
you do not need a very large cap after the requlator a 100 ~ 470uf shoud be there on the output of the regulator board ( close to the regulator output pins )and 2*1000uf ( one per rail ) on the amp board..( a small value 10uf or so and a film cap close to chip pins should already be there on the pcb )
Be sure to use the protection diodes for the regulators mentioned in the application note on the 15000uf before the regulator solder a 0.1uf ( ceramic preferably ) directly onto the cap legs. 30000uf should be sufficient for both your channels .. The MKP you mentioned at the end might already be present in form of a small bypass cap near the chip pins..( it should be a ceramic or tantalum rahter than film ) for bypassing powersupply a multilayer ceramic or even a disc type will perform better than MKP
#9 |
if you're going to use 2*LM3886 then 2 LM350's should just about do it, one on each rail i.e. one on +ve another on - ve.
If you're planning on paralelling you'll need 4 LM350... 2 per each rail and additional components like an opamp that will be used for paralelling the regulators. |
#10 |
You could always remove some of the secondary windings from the transformer. It might prove to be a huge ordeal, but will lower the voltage to what you need. The good thing is that you have a toroid type. These are much easier to unstack.
Tad |
| how to reduce PSU DC voltage | space2000 | Solid State | 11 | 18th May 2008 10:12 AM |
| PS Problem: How do I Reduce Voltage? | slor | Tubes / Valves | 7 | 27th April 2008 03:18 PM |
| How to reduce voltage from PSU?? | oblerum | Power Supplies | 4 | 10th August 2006 07:04 AM |
| Reduce wallwart voltage | argonrepublic | Parts | 2 | 19th February 2006 02:51 PM |
| basic question : reduce amps supplied by powersupply | fezz | Solid State | 0 | 26th March 2002 08:58 PM |
| Page generated in 0.10641 seconds (81.01% PHP - 18.99% MySQL) with 10 queries |
