Old 24th March 2009, 10:00 PM   #1
Default im an stupid? (comparing SQ)
Hi guys, let me introduce my question....
i was testing all the weekend 2 diferents amps
A - AudioSector Premium Kit LM3886 (1 hour burned)
B - Mauros GC (like 50 hours burned)
and i really cant find big diferences in sound!
Mainly the bass sound are diferent and the main diference that i found is that Amp B sounds like if more intruments/sounds are in the background, while Amp A sounds like more defined, with no extra sounds. Something like the sound are a little more defined,
Is that possible?
what i need to do to compare, how is possible that i cant find too much diference? :S
All the amps will sound the same :S
I have 1 LM3886 Standard kit to build, 1 LM4780 and others will tesst it maybe next week, now i will build the case for each mono amp.
I was comparing it playing the music at mono (same output in the diferents channels of the source), and using one amp/channel.
Old 24th March 2009, 10:19 PM   #2
Did it Himself
richie00boy's Avatar
No it's just that you are normal and of good mind The amps are fundamentally similar, and if using same kind of power supply for each then the result will be similar.
Amps do sound different but some things are hyped up, especially in chip amp land in my opinion!
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 24th March 2009, 10:29 PM   #3
analog_sa's Avatar
Default Re: im an stupid? (comparing SQ)
Millions (billions?) of people will hear even less difference. Not to mention some contributors at diyaudio who can scientifically prove there can be no difference. Otoh, comparing amps in mono is indeed stupid.
Old 24th March 2009, 10:35 PM   #4
CJ900RR is offline CJ900RR  Sweden
In the world of audio, the placebo effect is the most vital ingredient.
Old 24th March 2009, 10:46 PM   #5
tpsorin is offline tpsorin  Romania
Default Re: Re: im an stupid? (comparing SQ)
Comparing amps in mono is the best way to do it.
What speaker do you have? What source have you used?
Old 25th March 2009, 03:45 AM   #6
Default Re: Re: Re: im an stupid? (comparing SQ)
well some say that comparing amps in mono is indeed stupid. Others say that is the way to go :S
Damn, audio world is really hard to understand
Speakers that i have are Full Range CSS FR125S. Source PC with Onkyo SE-200 Sound Card (nice Card).
Old 25th March 2009, 04:24 AM   #7
ttan98 is offline ttan98  Australia
I assume the A and B amps are based on LM3886, I found amps with similar topology will give you similar sound characteristics. This assumes all being equal, eg no coupling caps or bypass caps on both, etc.
I am fairly confident that your new amp 4780 will sound similar too, dual LM3886 in one package.
You will find the LM3875 sounds slightly different. So do LM1875 etc. All chipamps have certain character very different from the T-amp.
Cheers
Old 25th March 2009, 06:11 AM   #8
Default Re: Re: Re: Re: im an stupid? (comparing SQ)
Depends on what the comparison is about. With a mono setup you can logically not find out, how good the spatial illusion is. On the other hand, if you use stereo, impulses are smeared and accuracy suffers. So you would attribute faults to the amplifier that are really due to the room, setup and speaker interaction.
Do both tests, mono and stereo.
Differences between amplifiers are usually small, and the better amplifiers are, the smaller are the differences. The differences that you heard, which seem small to you are a big issue for some people, others cannot even perceive them at all.
If you want big improvements, invest money and effort in speakers and the acoustic treatment of your room.
If you've always done it like that, then it's probably wrong. (Henry Ford)
Old 25th March 2009, 07:16 AM   #9
Electrons are yellow and more is better!
peranders's Avatar
You don't say? I thought everyone told me the truth.
/Per-Anders (my first name) or P-A as my friends call me
Old 25th March 2009, 08:17 AM   #10
analog_sa's Avatar
Really? It seems detecting minute timing differences between the ears is the one truly outstanding capability of the ear-brain interface. If you are building an amp for a mono setup, by all means make comparisons in mono.
Interestingly this observation is not new. At the time of the Williamson amplifier many builders found that while it was great in mono it was rather disappointing in stereo.
Comparing 3 topologies hahfran Solid State 19 24th November 2008 08:33 PM
Comparing two old MCM woofers diydave Multi-Way 1 27th August 2008 05:40 AM
Comparing Bose(o) Chip Amps 5 29th July 2005 09:19 PM
Comparing sensitivities Grahamt Multi-Way 2 20th September 2004 06:42 PM
Comparing GC's yuval Chip Amps 20 10th June 2004 05:26 PM
Page generated in 0.10539 seconds (88.63% PHP - 11.37% MySQL) with 10 queries
