Old 20th March 2009, 08:18 PM   #11
well on the noise side of things I'm using a filtered ac input module and the physical devices are going to be enclosed in metal (most likely a thin sheet of aluminum) then with another material (non metalic) around it. So the only exposed metalic surfaces would be the audio terminals which are grounded, the power switch, and the head sink which is at the very least isolated from the lm3875.
My ground system will consists of two parts. In the psu case the star point will be a bolt into the aluminum shell to which the ac ground, in case power ground, and the ground from the powercon conector from the amp (which is the ground like between the psu and amp).
In the amp I have the power ground and all of the power decoupling and bulk caps together while the input ground is connected to them via a 805 smd resistor on the pcb. The speaker return ground is just connected to the powercon ground connector. The only question that I have is should I have the ground from the feedback loop on the amp connected with the input ground or just with the power ground? And is there anything else I should do to the ac ground?
Old 20th March 2009, 09:59 PM   #12
h_a is offline h_a  Europe
h_a's Avatar
why don't you wire it point-to-point first? There are virtually no parts
That's done in a morning and in the afternoon you can already enjoy your amp
Have fun, Hannes
Old 20th March 2009, 11:24 PM   #13
Well i have 4 chips coming. I may bread board it but i really don't like point to point wiring. If i'm going to do something i'm going to do it right
PP KT88 Mono blocks? TubeMack Tubes / Valves 38 11th June 2009 06:41 PM
100watt mono blocks yise1 Tubes / Valves 2 27th August 2006 06:29 AM
Bridging Mono Blocks jwatts Tubes / Valves 8 12th February 2005 08:23 PM
Rogue 120 Mono Blocks illenema Tubes / Valves 0 3rd November 2003 02:17 PM
Page generated in 0.08378 seconds (63.95% PHP - 36.05% MySQL) with 10 queries
