| Chip Amps Amplifiers based on integrated circuits |
First of all thank you to everyone here. You are such a great source of information for a total beginner such as myself. I am considering building a chip amp and from what I can tell it seems like the LM1875 is the favourite of these two chips but I am concerned that it won't be enough to drive my speakers. I have Kef iq3's, 8 ohm, 89 dB. (spec - http://www.superfi.co.uk/index.cfm/p...roduct_ID/2490 ) Which chip would you recommend for my purposes? Also, would It be correct to say that the LM1875 has a more laid back smoother sound? My KEF's are quite aggressive and trebbly as they are so I wouldn't want to emphasise that any further. Any suggestions would be very welcome. Thank you |
#2 |
I would defenently use an LM3875 or LM3886.Between these two,I personally like the LM3875 better.
#3 |
I have both LM3886 and LM3875, I prefer the latter, better clarity.
#4 |
The LM3875 will be fine. Just because you read the LM1875 "has a more laid back smoother sound" doesn't mean that the LM3875 sounds in any way aggressive.
The truth need not be veiled, for it veils itself from the eyes of the ignorant. |
#5 |
I think those KEF speakers are 4 to 8ohm and not 8ohm. See the spec for minimum impedance of 3.2ohms. If these are using a 4ohm or 5ohm bass/mid driver with an 8ohm treble driver then you must design the amp as a 4ohm capable amplifier. The 3875 has a current limit ~ 60% of the 3886. The 1875 has an even lower current limit. I would recommend neither the 3875 nor the 1875 for this 4 to 8 ohm duty.
regards Andrew T. |
#6 |
I use the 3886 from chipamp.com with my B&W CM4's which are similar to your KEFs although a bit more efficient at 91dB...I like it a lot but I could use a bit more power - at high volumes the bass starts to clip a bit i think.
byron |
#7 |
Thank you for your replies.
If I were to build a LM3875 amp from a kit then which do you recommend? Chipamp.com don't appear to offer one. I liked the look of the kit at audio sector (http://www.audiosector.com/lm3875.shtml) but it says its dual mono? Does that mean I would need two transformers? sorry If I'm being stupid. Thanks again |
#8 |
you could use two transformers but a dual-secondary transformer will work just fine...Peter has a guide to the build of his kit somewhere on the site (I think it's a sticky in the chipamp forum)
Byron |
#9 |
Banned
I used a bridged 3886TF with one PCB for both amps and a balanced driver, Rod Elliot's P19 amp and P87B balanced driver. It drives my 8" Peerless woofer and doesn't have any problems even with high volume.
Frank |
#10 | |
http://uk.farnell.com/jsp/search/pro...sp?sku=9532838 On the kit guide he recommends a transformer with 220VA. Would that be per secondary or overall? Thank you |
| LM1875 design, help a newbie out | Bob0513 | Chip Amps | 10 | 15th August 2007 04:36 PM |
| LM3875 - newbie gainclone project | Grandma´s_SUB | Chip Amps | 32 | 14th May 2007 06:49 AM |
| Using the LM3886/LM3875/LM1875 for a HT amp set up | diarav | Chip Amps | 5 | 2nd April 2006 04:43 PM |
| lm1875 compared to LM3875? | skyraider | Chip Amps | 0 | 21st October 2004 09:13 AM |
| Observations requested: OPA vs LM vs TDA; LM1875 vs LM3875 - anyone compared them? | Morse | Chip Amps | 8 | 4th March 2004 04:48 PM |
| Page generated in 0.10064 seconds (78.58% PHP - 21.42% MySQL) with 10 queries |
