Old 17th March 2009, 10:33 PM   #1
lejaybo is offline lejaybo  United Kingdom
Default ghetto blaster
howdy peoples
i wanna make a simple ghetto blaster style portable system
doesn't have to sound the greatest but i'm looking for a simple amplifer that'll run of batteries
plus has anyone played with dab tuners?][;p
Old 18th March 2009, 03:53 AM   #2
im currentley working on a 2x 20 watt amp using the tda 2003 its quite cheap to make and decent sound quality i dont know what its like with regular batterys but it runs for a good time on my drill battery
anyway heres the circuit diagram for it
Old 18th March 2009, 04:22 AM   #3
star882 is offline star882  United States
star882's Avatar
There are plenty of hybrid digital chips designed for battery operation. Of course, pretty much all of them are SMD. But some of them are still easy to work with.
"Fully on MOSFET = closed switch, Fully off MOSFET = open switch, Half on MOSFET = poor imitation of Tiffany Yep." - also applies to IGBTs!
Old 18th March 2009, 07:46 AM   #4
sweet i'll have a butchers
i found some old low power 8inch cheap drivers
i wonder if thats a bit too much for a ghetto blaster lol
Old 18th March 2009, 10:02 AM   #5
Stuey is offline Stuey  Australia
Too much? Check this...!
The Boominator - another stab at the ultimate party machine
Old 18th March 2009, 10:05 AM   #6
benchtester's Avatar
Default Re: ghetto blaster
Originally posted by lejaybo
howdy peoples
Parts Express has a sale on a T-amp (today only?). Sounds pretty decent and is pretty efficient.
Old 18th March 2009, 10:34 AM   #7
for battery operation use high efficiency speakers.
8ohm >=96dB/W/m or 4ohm >=96dB/W/m>=99dB/2.83V/m
regards Andrew T.
Old 18th March 2009, 10:42 AM   #8
TEA2025 is a nice simple chip that will run BTL, runs of 6-12 volts, and will put 4.7 watts into an 8ohm speaker in BTL.
Idea chip for battery operated devices.
Old 18th March 2009, 10:54 PM   #9
johnr66 is offline johnr66  United States
What battery type do you plan to use? What voltage?
I just got some TDA7267 ICs. After doing careful tests with my oscilloscope and function generator, I found it to deliver 1.8 watts (non clipping) into a 5 Ohm load with a 9 volt Vs. This is very good performance for a single ended output IC. It requires very few components.
Old 19th March 2009, 07:47 AM   #10
cool info guys
i'm thinking roughly to use 9 to 12 volts
AA tyes me thinks, something thats easily avaiable
the best power i can get for this power is my aim
plus i know it'll sound a bit better than those plastic crapola boombox i keep seeing
anyone seen quad channel IC ?
diy ghetto speaker driver Tekko Multi-Way 8 6th December 2006 08:02 PM
Car Stereo Toolbox Construction Radio/Ghetto Blaster Project ibew1 Everything Else 2 25th April 2005 07:05 AM
Tube ghetto blaster ? heater Tubes / Valves 9 9th September 2004 05:10 PM
Building my own Ghetto Blaster ;-) Cradle22 Multi-Way 18 17th September 2003 09:41 PM
Page generated in 0.09688 seconds (76.59% PHP - 23.41% MySQL) with 11 queries
