Old 23rd March 2009, 12:44 PM   #21
domtw is offline domtw  France
domtw's Avatar
I haven't see it on the AN-1192 data sheet where the PA100 is described
It is on the LM3886 but I am not sure if the setup would be the same in a PA configuration...
Old 23rd March 2009, 01:34 PM   #22
not the application note (AN), the 3886 datasheet details it all
regards Andrew T.
Old 23rd March 2009, 02:18 PM   #23
Originally posted by domtw
As I am not 100% sure, I added them here to let you guys have a look:
The principle is correct.
What should be the value of Cs ?
As AndrewT stated, it is all in the datasheet
What about the pin 8 (mute), if I don't use it, should I connect somewhere?
If you don't use it, no music will come out of the amplifier. You need to connect at least a resistor to V- there. The size of it depends on the rail voltage you use. The formula is in the datasheet.
I apparently found a local supplier from who I could buy empty PCB for a single chip LM3886 amplifier. I will probably get one to check if I can use 2 of them in a parallel setup.
Parallel application was already planned for this PCB, because there is a place for the load sharing resistor (R1). On the other hand it looks, as if there is only space for small Cs on board and the 100 nF decoupling caps will have to be soldered directly to the IC pins, because there is no place for them.
If you've always done it like that, then it's probably wrong. (Henry Ford)
Multi-purpose tube amp (line and guitar inputs) smsmonster Tubes / Valves 28 20th May 2006 12:12 AM
Purpose of this capacitor in discrete amplifier? fluckscapacitor Solid State 35 5th September 2005 01:20 AM
multi-channel amplifier power supplies MikeA Solid State 20 8th April 2004 01:03 PM
Multi purpose multi channel gainclone PCB: Team project - group buy rick57 Chip Amps 14 29th March 2003 05:54 PM
Page generated in 0.07629 seconds (73.38% PHP - 26.62% MySQL) with 10 queries
