Old 11th March 2009, 03:37 PM   #1
Default I think my preamp cooked my speakers HELP
hooked up the preamp last night and it sounded distorted when i turned it up i looked over at my speakers and the woofer cone was flexed all the way out like the speaker was tring to turn it self inside out i went over to the speaker and it was smoking so i disconected the preamp hooked up my cd player to the amp then tried the speakers now the mids and highs are all crackely i think the speakers are shot what do you think let me know thanks merick
Old 11th March 2009, 04:00 PM   #2
Default overheated speaker
No DC blocking capacitor in the source output nor in the power amp input.
No DC detection circuitry in the power amp.
No speaker protection fuses in the supply rails of the power amp.
regards Andrew T.
Old 11th March 2009, 04:18 PM   #3
analog_sa's Avatar
The sickening smell of burning speaker-flesh. A tube amp will never do this. Not counting OTLs.
Old 11th March 2009, 05:01 PM   #4
Default Re: I think my preamp cooked my speakers HELP
At least the woofers and maybe some components in the crossover. The other drivers should have survived. Disconnect the woofers and check, if the crackling goes away. Maybe it is the protection cicruit reacting to the partly fused voicecoils.
If you've always done it like that, then it's probably wrong. (Henry Ford)
Old 11th March 2009, 05:59 PM   #5
ok does anyone know what to do about this the speakers are fostex 207e f range so how can i check to see what caused the problem im new to this how do i take a reading with a metter and what setting should it be on
Old 11th March 2009, 08:11 PM   #6
Puffin is offline Puffin  United Kingdom
give us full details of the pre-amp and power amps.
Old 11th March 2009, 08:25 PM   #7
this is the amp that i built
http://www.chipamp.com/lm1875.shtml
here is the pre amp that i built it a bugal
http://www.hagtech.com/bugle.html
any help would be great
Old 11th March 2009, 08:30 PM   #8
im sorry the chip amp i built is the LM3886 Amplifier Kit
http://www.chipamp.com/lm3886.shtml
Old 11th March 2009, 09:23 PM   #9
I´m amazed!
Groundloops's Avatar
Lightbulb CDP into RIAA preamp?
Did I get that right - The chain is CD player -> Bugle -> amplifier? You are aware that the Bugle is a RIAA phono preamp?
Old 11th March 2009, 09:35 PM   #10
no im sorry i had the recored player to the phone preamp hooked up to the amp then to the speakers after that i then took out the phono preamp hooked up the cd player to the amp
Are these tubes cooked? Mike L. Tubes / Valves 8 20th October 2008 03:20 AM
DIY Speakers and Preamp for Leach 4.5 quamen Solid State 1 14th August 2006 01:09 AM
WTB: Mic + preamp for measuring speakers Saurav Swap Meet 2 6th October 2004 06:13 PM
Few cooked amps .. . DilutedImage Car Audio 4 7th August 2004 05:58 PM
Cooked CS8414??? TV Man Digital Source 8 8th January 2003 02:06 PM
Page generated in 0.10051 seconds (78.54% PHP - 21.46% MySQL) with 10 queries
