Old 11th March 2009, 06:08 AM   #1
Default lm1875 psu design
Ok well I had some time to work on the PSU for my amp today. I've poured through all of the psu guides and I think I am close. The only thing I'm not sure of is how it will work with the toroid I am trying to get (25-0-25 dual seconds 160va from a group buy). I'm not sure if the 1875 can take the rails that will result.
anyway here is the schematic for the PSU NOTE: I an using mur860s in it but all eagle had was the 820. Same size just didn't want to make a new part because of a name difference
The bulk caps are nichcon ones and all of the others are wima poly film.
Here is the layout thus far
Hows it looking?
Old 11th March 2009, 07:04 AM   #2
kaos is offline kaos  United States
Aaaaak … the LM1875 is only rated for 60V (+/- 30V) max. The dual 25 volt transformer will yield approximately +/- 34 volts (68 V total) of rectified DC.
I’d go for a transformer with dual 18 volt secondaries, which would yield approximately +/- 24 volt rails. At that voltage the chips can be expected to idle at 3.36 watts each typical (4.8 watts max).
On the layout I think I’d beef up the ground bus too. Also, the D5-D8 diodes appear to be backwards (I think, unless you plan on mounting them upside down, or will the diodes stand up?). Looks like they're backwards in the schematic too.
Old 11th March 2009, 08:19 AM   #3
..if your speakers are 8 Ohm. With 4 Ohm speakers use a 2*15 V transformer.
Did you use the correct package for C1-C8? They look quite big for 22 nF.
If you've always done it like that, then it's probably wrong. (Henry Ford)
Old 11th March 2009, 09:36 AM   #4
allow pads for R+C snubber across the bridge diodes.
There is a risk of oscillation with an undamped C across the diodes.
regards Andrew T.
Old 11th March 2009, 02:13 PM   #5
I've upped the ground trace to .15 inch so that should be better. I may just used this for a lm3886 instead. In which case I will make a seprate board for the cap bank and up them to about 10k uf per channel.
On the diode r+c network what should I use for the resistor to pair with a 22nf cap?
The 22nf caps are 630v with a 10mm grid. Its just a large size cap I double checked the package size (4.3x13.3)
Old 11th March 2009, 02:24 PM   #6
a 5mm package will have about half the inductance of a 10mm package if it's been produced as a low inductance type.
Don't worry about resistor values just now.
They will need adjusting once you get a scope on the supply rails.
regards Andrew T.
Old 11th March 2009, 09:18 PM   #7
ok I switched to wima PP film caps in the 5mm grid so now they are about 7.5x7.5 square. What resistors should I use for the filter? Carbons are massive at 6x15 mm. Is there something smaller that I can use and what wattage for them? Carlosfm made reference to carbon or film resistors in a rc filter but i'm not sure if those are carbon film or metal film.
Old 12th March 2009, 07:56 AM   #8
use 1% metal film.
anywhere from 250mW to 600mW.
regards Andrew T.
Old 12th March 2009, 10:19 AM   #9
Greg Erskine's Avatar
Hi BionicSniper,
Here's a similar layout. Note that diodes D2 and D4 are flipped over.
regards
Greg Erskine
Old 12th March 2009, 12:23 PM   #10
audio1st's Avatar
I'm sure BionicSnipers diodes are correct..
Mini LM1875 design BWRX Chip Amps 155 12th September 2011 04:44 PM
LM1875 design advise.... setting son Chip Amps 7 27th October 2006 11:24 AM
LM1875 - pcb design zatramusic Chip Amps 2 15th February 2006 06:13 AM
the best PCB design and schematic for the LM1875? lutherblisset Chip Amps 0 29th October 2004 01:40 PM
Page generated in 0.11426 seconds (80.59% PHP - 19.41% MySQL) with 11 queries
