is there a chip amp that will give me 50 watts of power
Old 6th March 2009, 08:39 PM   #1
merickrc is offline merickrc  United States
Default is there a chip amp that will give me 50 watts of power
i am looking to build a chip amp that will power these speakers http://www.zaphaudio.com/BAMTM.html is there a chip amp that will give me 50 watts of power per chan
Old 6th March 2009, 09:04 PM   #2
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
What is the impedance of those speakers?
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Old 6th March 2009, 09:10 PM   #3
8 ohms
Old 6th March 2009, 09:14 PM   #4
PSz. is offline PSz.  United States
PSz.'s Avatar
LM3886
Old 6th March 2009, 09:16 PM   #5
Nuuk's Avatar
Yes, an LM3886 based chip amp with a power supply or around +/-36 volts should do. You may even get away with an LM3875 too.
Old 7th March 2009, 12:14 AM   #6
thanks for all the help so far will this kit work http://www.chipamp.com/lm3886.shtml
LM3886 Amplifier Kit
Old 7th March 2009, 02:04 AM   #7
mikejennens is offline mikejennens  United States
This speaker DIY thing, it's pretty addicting!
mikejennens's Avatar
merickrc,
I run a set of JBL L40 speakers, 8 ohm, from an LM3875 (56 wpc, I think). I am extremely pleased with this set-up . Plus, Peter Daniel (www.audiosector.com) was very helpful, very prompt with replies, while I was building the amp. I'd do another LM3875 without batting an eye .
Mike
Jolida SJ502A, Squeezebox Touch, Paul Carmody's Sunflowers, Jeff Bagby's Continuums; Planet 10 HiFi's MarkAudio A 7.3 Frugalhorns and MarkAudio CHP-70s, Nola Brio Clones with a Voxel Sub and a bunch of others...
Old 7th March 2009, 02:39 AM   #8
woody is offline woody
Merickrc, this speaker uses 2 8ohm woffers in parallel so it is
a 4ohm speaker.
Old 7th March 2009, 03:10 AM   #9
Old 7th March 2009, 04:28 AM   #10
star882 is offline star882  United States
star882's Avatar
Originally posted by PSz.
LM3886
That's a pretty inefficient chip. A TDA8920B will easily handle over 50W per channel and is much more efficient. (Aside from lower operating costs, it also means a cheaper power supply and smaller heatsinks.)
"Fully on MOSFET = closed switch, Fully off MOSFET = open switch, Half on MOSFET = poor imitation of Tiffany Yep." - also applies to IGBTs!
is there a chip amp that will give me 50 watts of powerHide this!Advertise here!
Good chip for 5 Watts or so into 8 Ohm? Omega_Void Chip Amps 7 29th October 2008 07:51 PM
how much power should give guitar ??? prorms Instruments and Amps 9 30th January 2008 07:06 PM
Please give function of C5185C chip kelticwizard Parts 9 1st June 2005 08:59 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 06:25 AM
How much power can a Sanui 300watt max amp really give? ;) SkinnyBoy Car Audio 8 2nd June 2004 12:33 PM
