| Chip Amps Amplifiers based on integrated circuits |
I need to take about .2 dc volts and increase it to about 5 volts. Is there a simple circuit to achieve this? The voltage is supplied when a piezo transducer is struck and the amp can not produce any voltage when it is not being struck. I googled it, but I ended up more confused than when I started. THIS looks promising, but it starts with a voltage of .7.
Please let me know if you have any ideas on this. Thanks Jeremy |
#2 |
Waaaaaaaaa?
Do you need a DC/DC converter or an amplifier? They are two different things. An amplifier is a powered device that can take your 0.2V and amplify it to 5V. A DC/DC converter would (in theory) take the 0.2V and boost it to 5V. That's not going to happen though.
"If you don't like funerals don't kick sand in Ninja's face." - Ninja |
#3 |
Jeremy
It will be better if you describe exactly what you want to achieve. Is it really a dc amplifier or are you amplifiying the signal from the piezo transducer? Or is it just a circuit which switches between two output voltages? |
#4 |
HERE is what I am trying to achieve. I don't know exactly what I need. I didn't get any responses on this so I decided to try a different idea. If you can make head or tails of what I am trying to accomplish and can help me, I could sure use it!
Thanks |
#5 |
You could use an op amp as amplifier, e. g. like here on page 2, figure 2. R1 = 270 Ohm, R2 = 6,8 kOhm could give you the gain you want.
If you've always done it like that, then it's probably wrong. (Henry Ford) |
#6 |
Thanks guys. I have come pretty close to what I'm after using this circuit here. I just have to figure out now how to make the LED flash much brighter.
#7 |
Doesn't seem like it will work with R3. Actually most of the parts in your circuit, athough fine by themselves, don't make too much sense together. Once you fix your circuit a bit a darlington may provide the missing brighness.
#8 | |
Thanks Jman |
#9 |
If it works very well then your circuit is wrong as it shows the led getting current through a 1M resistor.
#10 |
I'm sure you are right, can you expound on what you are getting at. Obviously I don't know what I am doing or I wouldn't be having problems with a circuit that only has five parts. So rather than making comments about what I'm doing wrong, please help me make a circuit that will work. I don't mean to be rude, but if I had the answers I wouldn't be asking you to help.
If you don't want to help, I understand, but It doesn't do me any good for you to make comments that make no sense to an average guy like me trying to get an understanding of what I am doing. I really mean no offense, but I just don't have the knowledge that it takes to understand your reasoning. Jman |
| Simple Low Voltage Tube Preamp? | CarlosT | Tubes / Valves | 11 | 1st February 2007 10:25 AM |
| Simple, SIMPLE Digital volume control | -_nando-_ | Digital Source | 5 | 21st December 2006 01:20 PM |
| Simple Low Power Voltage Regulator | rjm | Power Supplies | 18 | 28th September 2005 03:48 PM |
| Simple answer required for a simple question... | rabbitz | Multi-Way | 4 | 31st August 2003 10:05 AM |
| Page generated in 0.09920 seconds (81.59% PHP - 18.41% MySQL) with 11 queries |
