DIY Amplifier Suggestions - on a tight budget - Page 9 - diyAudio
Old 22nd April 2003, 08:07 PM   #81
jackinnj: that's pretty sweet! look at those nifty meters. and those honkin handles.
did you get it off ebay, or do you have some top-secret source you're willing to reveal?
/andrew - thinks 19 bucks is a pretty nice deal.
Old 22nd April 2003, 10:34 PM   #82
jackinnj's Avatar
Default it was on EBay
the HP6129C, HP6130C, HP6131C are all voltage amplifiers - with +/- 95 and +/- 75 volt rails.
you just have to keep checking the power supplies section on EBay under ( I hope this pastes correctly http://listings.ebay.com/aw/plisting....html?from=R11
Old 23rd April 2003, 05:23 PM   #83
elizard is offline elizard  Canada
Send a message via MSN to elizard
one last question before i order from partsconnexion
they have the 10k, 1% 1W Riken resistor
but they don't have a 220k Holco 1/2W/1% .. they have a 200k and a 237k one
now .. they do have a 220k 1/2W 1% Riken resistor, should i just get that?
Old 23rd April 2003, 05:28 PM   #84
I have found this same problem, most places have 221K resistors not 220K.
Is it ok to use 221K? Where do people source their 220K resistors from?
KevinLee
Old 23rd April 2003, 05:35 PM   #85
JOE DIRT®'s Avatar
Jack...we pay a fortune for test equipment like that here in Canada....that power supply you showed would go for atleast 200 CAN here..............and partsconnexion...nice products....but they are the most expensive place I`ve seen....I buy from other places and their store is a half an hour away
Cheers!!The DIRT®
Old 23rd April 2003, 05:45 PM   #86
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
I used Holcos in one of my first amp, but after that I'm using 220K Rikens from Parts Connexion. It doesn't matter what the value really is, 200K is good too
I had Vishay S102 in that location as well. 200K cost around $28 for one, but eventually I think I prefer Riken, as being more open, detailed and fast. My friends didn't like Vishay as being too laid back.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 23rd April 2003, 07:04 PM   #87
well well .. i got all the digikey stuff, in satisfactory condition
plus it was overnight shipment for $8 .. THAT'S freakin cheap
i just ordered the stuff from partsconnexion .. hope they get the order right
they weren't quite as friendly as plitron to order from, but bleh .. so long as the order is right, i'm satisfied
now the only thing i'm going to be waiting a WHILE for is the torroid .. i'm gonna die waiting 4-5 weeks!!!
i think maybe i'll design the chassis while waiting
which reminds me .. Peter, do you have the dimensions of the 400VA torroid from plitron?
i'd need the diameter and the heights of it .. i know its 4kg .. yikes
gonna work with possibly 5mm aluminum if i can find some cheap
Old 26th April 2003, 07:39 AM   #88
JAZZ2250's Avatar
Default ultra-low budget gainclone
Hmmm... It seems this is the place that I can post what I'm doing these days. I'm building a ultra-low budget Gainclone while I'm thinking/reading some tube related stuffs.
Attached is an LM3875-based "unity gain" gainclone which will be used as a PC soundcard amplifier. As stated above, this is an ultra-low budget project. So, there is no Blackgate, Holco, Riken, etc. Just cheap 0.22uF polyester bypass film caps, 2200uF electrolytic caps from Allelectronics, metal film resistors from Digikey, Transformer from PartsExpress, etc. I'll have to drills some holes on the chassis tomorrow. Cutting a square hole for AC power connector is always a pain. ?
Elizard,
How's your work going? Any progress on chassis design?
Old 26th April 2003, 07:58 AM   #89
no, haven't actually designed anything yet ..
i don't have all the parts .. i didn't receive the partsconnexion stuff yet (resistors/4.7uF cap) .. and i don't have the transformer
i did build one power cable that'll go from the PS to the GC .. wow .. took a LOT of work (2 hands, no vice .. painful to solder the connections) .. but one is done
i ended up using 22g magnet wire .. works fine so far
but i've exams monday, so can't spend time on this till i'm done that
i'm planning on the above idea as far as the chassis goes .. an opening for the toroid
should be interesting
Old 27th April 2003, 05:24 AM   #90
well .. so far so good
sorta
i just finished making the power cables .. boy they're a pain in the rear if you don't have a vice (or someone else) ..
one unfortunately turned out about 2"-3" longer than the other somehow, but whatever .. its just dc current anyway, shouldn't be a big deal
not like its a signal .. although it would have been nicer had they been equal .. but meh ..
the way i made each cord is from 4 lengths of 22g magnet wire from ratshack, each soldered to the pins on the 4 pin connectors (that's the hard part)
then i isolate each soldering w/ some heatshrink tubing, and run it through some cat5 tubing (i took out the cat5 wires and ran the magnet wire through that .. works fine except its a little loose, but provides for good flexibility!) ..
i'm gonna get a digicam soon from a friend and post some pics .. maybe i'll wait till i get everything
now i'm gonna go take my dvd player apart .. i think it has like a very small 9v transformer inside .. which would do great for the LED
no need for extra windings
The Missing element in Chipamps> how to achieve tight kick drum bass with chipamp? rhythmdiy Chip Amps 37 25th November 2013 06:15 PM
why bass is tight and controlled on SS than chipamps like lm3886? rhythmdiy Solid State 46 14th December 2008 01:32 PM
Tight bearings in Rega RB250 denied Analogue Source 10 12th March 2007 11:25 PM
fast tight small OB sub inrank Subwoofers 3 31st July 2006 01:19 PM
The Next Step. (and budget tube amplifier kits/designs). percy Tubes / Valves 15 18th August 2004 07:45 PM
Copyright ©1999-2017 diyAudio
