Old 4th March 2009, 03:40 AM   #1
Default Adding a Potentiometer
I'm trying to build this design:
http://www.shine7.com/audio/pa100.htm
I've realized that it doesn't have a volume control potentiometer and i want to add it.
How can i do this?
Is it correct to connect both R2 and R7 to the middle of the potentiometer? Then, one side to ground the other to the RCA In filter (R1-C1) ¿?
Thanks a lot !
Old 4th March 2009, 04:23 AM   #2
col is offline col  Australia
col's Avatar
http://sound.westhost.com/pots.htm
col.
http://www.minirig.org.au
Old 4th March 2009, 09:06 PM   #3
J1 Pin1 connects to pot wiper.
J1 Pin2 connects to pot return (bottom).
RCA pole connects to pot input (top).
RCA barrel connects to pot return.
regards Andrew T.
Old 5th March 2009, 10:19 AM   #4
sasmit is offline sasmit  India
Send a message via Yahoo to sasmit
a very simple way is...the middle pin of the common 3 terminal pots is where u have take the input to your amp..
2 pins remain....to one of them connect your amp and the input signals ground
To the one remaining pin..connect the signal from the input source.
Only one rule applies, the middle pin is the pin from which you have to take the signal to the amp..
The pot will work even if you exchange the other two pins ( 1 & 3 ) positions but it's direction will change from Clockwise to anticlockwise.
Old 19th March 2009, 01:30 PM   #5
Havoc08 is offline Havoc08  Denmark
Send a message via MSN to Havoc08
When choosing a pot, does it need to be an effect pot that handles xx watts or is a normal pot adequate when used on input signal?
Also what decides whether to use a log or a linear pot and which ohmic value you need?
Old 19th March 2009, 01:35 PM   #6
u don't need too much power handling capacity , most pots are rated around 0.25W, generally a log taper is used.
Loudness increases, I mean dB is a logarithmic measure and human ears also perceive loudness change in logarithmic fashion ( in theory...).
A linear taper would work far too abruptly..a little turn of the knob would blast the hell out of you..
Old 19th March 2009, 01:41 PM   #7
hehe okay.
What decides the ohmic valu needed then? Trial and error or can you calculate it?
Old 19th March 2009, 04:28 PM   #8
keep the pot resistance as low as all your sources are able to drive.
As a starter try comparing 10k to the specifications for minimum load resistance, of what you might want to connect to it.
If the power amp is also low in input impedance (Zin<20k) you have a problem that a pot alone is unlikely to solve.
regards Andrew T.
Old 19th March 2009, 06:05 PM   #9
AndrewT
My amp says RIN Input Impedance min. 43kΩ nom. 50kΩ max. 57kΩ
Does this mean I should take a 50kΩ pot or should I somehow take into account the resistance from the source also?
Old 20th March 2009, 08:46 AM   #10
Hi Havoc,
a 10k pot will work with your Rin=50k, but you must keep the cables short. That places the volume control near the amplifier. If you can operate like this then OK.
Now check all the sources that may need to drive the 10k pot.
Are they able to do this?
regards Andrew T.
Which value of a potentiometer Alfetta87 Tubes / Valves 9 29th April 2008 12:56 PM
rca potentiometer Clipped Car Audio 5 24th January 2008 11:32 PM
LED potentiometer ralf Pass Labs 20 19th October 2006 05:37 PM
potentiometer log? audiofan Solid State 1 15th May 2006 03:32 PM
Potentiometer Value hongrn Parts 1 7th October 2005 07:41 PM
Page generated in 0.10397 seconds (81.58% PHP - 18.42% MySQL) with 11 queries
