tube preamp to mate with Gainclone
Old 20th April 2003, 05:12 AM   #21
JAZZ2250 is offline JAZZ2250
JAZZ2250's Avatar
Thanks everyone for your comments.
Now, what tube preamp to start with, please?
Old 20th April 2003, 06:48 AM   #22
Steve Eddy is offline Steve Eddy  United States
Steve Eddy's Avatar
Uh... er... um... I gotta go wash dishes.
Are you opposed to kits? If not, how 'bout something like the <a href="http://www.bottlehead.com/et/et.html">Bottlehead</a> Foreplay? If you haven't done anything with tubes before, it'd be a perfect way to get your feet wet.
se
Old 20th April 2003, 03:30 PM   #23
JAZZ2250's Avatar
Originally posted by Steve Eddy
Are you opposed to kits? If not, how 'bout something like the &lt;a href=&quot;http://www.bottlehead.com/et/et.html...head&lt;/a&gt; Foreplay? If you haven't done anything with tubes before, it'd be a perfect way to get your feet wet.
Thanks, SE.
Foreplay was the first one that I could think of, actually. I have no doubt that the Foreplay is the bang for the buck. But, I also think that I could make better one at the same price if I go a complete DIY-way. I already have a good enclosure, RCA connectors, etc. So, I would not like to spend my hard-earned money to the parts that I don't want/need/like. Am I too picky?
Maybe Joel's preamp?
Old 20th April 2003, 04:20 PM   #24
Steve Eddy's Avatar
Too picky? Naaaaaah. Just that as I said, tubes aren't my forte so I don't keep track of any of the various DIY tube circuits out there but I am familiar with the Foreplay and thought I'd throw that out seeing as the true bottleheads here can't seem to muster so much as a single suggestion for you. At least I tried.
se
Old 20th April 2003, 05:02 PM   #25
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
Default PREAMP.
Actually that's a headphone amp doubling as a preamp.
You could build it but did you browse around a bit here?
The previous pages of the "Tubes" section should contain at least a dozen of such projects....probably the main reason why the "bottleheads" around here haven't jumped in yet.
OTOH if you can provide a description of your requirements we may be able to get you started.
Frank
Old 20th April 2003, 05:14 PM   #26
Steve Eddy's Avatar
Default Re: PREAMP.
Originally posted by fdegrove
The previous pages of the &quot;Tubes&quot; section should contain at least a dozen of such projects....probably the main reason why the &quot;bottleheads&quot; around here haven't jumped in yet.
He wasn't just looking for circuits. He was looking for recommendations to suit his stated goal.
<i>I would like to get some recommendation from the tube guys here which project would be good for my plan.</i>
He laid it all out in his very first post.
I guess that's what you missed.
se
Old 20th April 2003, 05:23 PM   #27
fdegrove's Avatar
Default RE:RE:PREAMP.
From the first post:
Gain of 20-25 dB should be high enough for me. Thanks.
There's more to a preamp than just that piece of info alone in my book.
Add to that that the preamp needs low Zo and your stuck with the classic "anode follower + cathode follower" recipe or an SRPP.
Source selector, volumecontrol and the most overlooked part : the PSU.
Tubes: 12AU7A,12BH7A,12/6CG7,6DJ8 in short anything with a u of 10-30.
As said before there a number of those around here already.
Nope.
Frank
Old 20th April 2003, 06:29 PM   #28
Steve Eddy's Avatar
Default Re: RE:RE:PREAMP.
Add to that that the preamp needs low Zo and your stuck with the classic &quot;anode follower + cathode follower&quot; recipe or an SRPP.
Yes. But since he has no experience along those lines, he's relying on the judgement of others to make some specific recommendations that he can consider.
Do you expect him to try every iteration out there until he happens to come across something he likes? If that were the case, he wouldn't be here asking for specific recommendations. He'd be busy breathing solder fumes for the next six months.
se
Old 20th April 2003, 06:35 PM   #29
JAZZ2250's Avatar
Default Re: PREAMP.
I don't think you're missing anything.
Yes, I did looked around the tube forum. But, you know what? A newbie (to tube) like me feels even scared what to choose among the dozen projects here. I hope you understand it.
OK. Back to the topic. How's Joel's project? If I could have a headphone amplifier together with a preamp, that would be even better though headphone amplifier was not included in my initial plan. What's the Zo of his? Is it ~2.7k according to the last resistor at the output?
Old 20th April 2003, 06:52 PM   #30
fdegrove's Avatar
Default Re:re:preamp.
How's Joel's project? If I could have a headphone amplifier together with a preamp, that would be even better though headphone amplifier was not included in my initial plan. What's the Zo of it? Is it ~2.7k according to the last resistor at the output?
Well, Burnedfingers/Joe built it but had difficulties getting it to bias correctly.
From the feedback he gives it doesn't sound all that exceptional, no surprise there since it was basically just an headphone amp Joel designed to kick his cans.
It can be pushed to sound really great but that's not quite beginners territory.
I think if you look for a preamp + headphone amp, than a really good one can be made based around a circuit presented by Aren Van Waarde at the Headwize site.
It comprises a 6DJ8 and a 6080/6AS7G, the end result will depend on how far you want to take it but it has a lot of potential.
Many other possibilities exist and you'll likely hear other bells chiming here.
For someone new to tubes however is has the advantage to operate at relatively low voltages which will bring cost down.
I'll try to find the circuit for you and post it here.
P.S.If you're on a specific budget, pls. let us know.
Frank
tube preamp to mate with GaincloneHide this!Advertise here!
Tube Preamp Popping on Source Input Change (?) / 6DJ8 Preamp On Chip Amps Travis Clarke Tubes / Valves 3 16th October 2008 04:52 AM
Tube Preamp for Inverted Gainclone 5150ed Chip Amps 0 14th July 2006 03:23 PM
Best line stage preamp to mate with the Zen v9? jimmyd53 Pass Labs 4 19th June 2006 11:45 PM
gainclone with tube preamp TomekZ Chip Amps 2 31st December 2004 09:12 PM
