Problem with Lm3886 output voltage
Old 2nd March 2009, 02:05 AM   #1
JohnnyP00 is offline JohnnyP00  Canada
Default Problem with Lm3886 output voltage
My output voltage is about 20% higher out of the right terminals. I haven't hooked up any speakers yet but measurements with my meter shows more output gain on one side.
A little info: BrianGT's Stereo kit with Antek 300v 22v rails.
Measured the secondary voltage and everything was perfect: around 32v dc each. Hooked up the chips and now have what seems to me more gain on the right. Only thing that's different to me is the length of cable is longer to the left. Could this be it.
Don't want to hook up speakers to it yet so any help would greatly be appreciated... Thanks JohnnyP.
Old 2nd March 2009, 08:43 AM   #2
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
What do you call output voltage and what exactly do you measure?
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Old 2nd March 2009, 08:50 AM   #3
Johnny693 is offline Johnny693  Greece
No way
Old 2nd March 2009, 10:46 AM   #4
audio1st is offline audio1st  United Kingdom
audio1st's Avatar
How well matched are your NFB resistors?
Have you used a 10k by mistake?
Old 2nd March 2009, 02:33 PM   #5
sivan_and is offline sivan_and  India
sivan_and's Avatar
Send a message via Yahoo to sivan_and
Gain or OFFSET ?
SivanandBalan
Old 2nd March 2009, 09:47 PM   #6
I followed the instructions as per BrianGt's kit.
He states "measure the output DC voltage between the + and - output terminals to verify that a low DC offset is obtained."
I did that and also measured the ohms just to see if there was a difference.
I used the kit so unless I screwed up a resistor, didn't really check the tolerances too closely. I'm going to comb through it again... Thanks for your help... JohnnyP.
Old 2nd March 2009, 09:53 PM   #7
Nuuk's Avatar
But what did you measure? If you measured mV's of offset and had say 32mV on one channel and 75mV on the other, that is 'normal' and is down to the variations in the chips.
Old 2nd March 2009, 09:59 PM   #8
I'm a noobie when it comes to measuring DC so this could be wrong. I got 104 for the left and 92 mV for the right.
using the ohm setting I got 222 and 196. Which from what I understand doesn't mean anything but shouldn't they be closer in tolerances... JohnnyP.
Old 2nd March 2009, 10:03 PM   #9
Nuuk's Avatar
92mV and 104mV are OKish.
If you are a newbie then may I suggest that you go here and do some homework!
Old 2nd March 2009, 10:13 PM   #10
I didn't install the dc offset cap(Ci). I'm thinking that's maybe why my DC offset is high. From what I understand it should be safe to wire speakers, I hope!!!
At this point is there anything I could do without replacing resistors to make them more identical...
Thanks for the info and all of your help... JohnnyP.
Problem with Lm3886 output voltageHide this!Advertise here!
Aleph 30 problem - half of power supply voltage on speakers output yoke Pass Labs 18 15th March 2009 06:18 PM
Can An Output Transformer Change A Voltage Amp's Output Impedance From 0.1 To 47 Ohms kelticwizard Everything Else 11 25th March 2007 06:17 AM
Max supply voltage for LM3886 @ 4 Ohms madscience Chip Amps 8 4th October 2005 07:00 PM
LM3886 (or similar) as voltage regulator mirlo Solid State 4 13th January 2005 04:25 AM
LM3886 voltage xplod1236 Chip Amps 2 5th February 2004 09:25 AM
