| Chip Amps Amplifiers based on integrated circuits |
Here's my situation. When recording music, I have a mixing board that runs into my computer. From there it goes to an M-Audio sound card that puts out the sound. I was running that through a Peavey 6 channel mixer/amp to a couple of JVC home stereo speakers. (12" with mids and highs)
I recently had a rift with the guy in my band that was supplying the Peavey amp/mixer and now I have nothing to play the finished music through after we record a song. With those details in mind, and the fact that I know nothing about tube amps, I want to build the best possible chip amp to replace the mixer that I was using. My requirements are: 1. I need a volume control. 2. I would prefer basic bass, mids and treble control. 3. I need it to drive the speakers mentioned. 4. I need a very clean output for listening to our recorded tacks through. With these details in mind, can someone recommend the best amp that would satisfy all of these requirements? I am a fairly skilled builder, and I can make my own pcb's (which I prefer), so complicated or high parts count is not a problem. However, I don't want to over build. Any help would be greatly appreciated!! Thanks Jeremy |
#2 | ||
LM3875 and LM3886 will be the most promising choices. Quote:
If you've always done it like that, then it's probably wrong. (Henry Ford) |
#3 | |
I guess I phrased that wrong when I said the best possible amp. What I meant was the one best suited for my application. I will take a look at your suggestions!Thanks! |
#4 |
I am going to build this EQ/AMP suggested by PacificBlue. I have etched two of the boards because I want to have this be stereo. I intend to use dual gang pots so that both of them will be set the same. I have two 8 ohm house stereo speakers (with bass, mids and highs in one box) that I will use this on coming from my M-Audio Delta 1010lt sound card in my computer. Is there any reason that this won't work?
Thanks Jman 31 |
#5 | |
I would go for a simple used amp with low distortion and linear response
and then spend some money or elbow grease on studio monitors instead of putting a lot of effort into building some amp and driving home stereo speakers. A final mix is not done on your setup imho. Quote:
http://tda1541a.com The Final List |
#6 |
That link goes only to the equalizer. Which amplifier will you use?
#9 |
Both amplifiers are mixed AC- and DC-coupled, which is not recommendable.
The first amplifier's layout of 25k potentiometer followed by 1k blocking resistor and 22k to ground is not very promising. The second amplifier is optimized as a guitar amplifier, therefore C3 is very small and gives a roll-off at ~16 Hz, meaning audibly reduced bass performance up to ~80 Hz. Well calculated, because 80 Hz is the lowest note of an electric guitar, but not for instruments that go lower. Both amplifiers need an RF filter at the input and a Zobel network should be added to the second as well. Here at the bottom is one possible solution for a power supply. And here is a totally different approach.
#10 |
Thanks once again PacificBlue! I am awed by how much I don't know!
And how much you and others do. Every time I think I am getting a grasp on this stuff, I realize just how little I do understand.I like that last option that you presented. looks (to me) like it should do what I am after. Like I said though, I am realizing quickly that what I know and what I would like to know are worlds apart! |
| VHS for recording and playback? | systemerror909 | Analogue Source | 32 | 2nd September 2011 08:16 AM |
| Mac vs PC Encoding/Playback | JimOfOakCreek | Digital Source | 19 | 4th March 2008 09:40 PM |
| Non oversampling CD-playback, which way should I go? | stefanK | Digital Source | 17 | 25th March 2006 08:26 PM |
| 24/96 playback question | brsanko | Digital Source | 1 | 22nd February 2005 07:24 PM |
| Page generated in 0.13597 seconds (83.14% PHP - 16.86% MySQL) with 11 queries |
