| Chip Amps Amplifiers based on integrated circuits |
I have an LM3875 kit from audiosector.com and I happen to have an Avel 250VA 25v transformer kicking around. Looking at the datasheet and reading in the forums here, it appears as though 25v is the upper end of what will work well for an 8 ohm load. I thought I had 8 ohm speakers, but checking the impedance graph and reading the plans, it appears as though the nominal impedance is more like 4 ohms. See the attached graph.
So my question is, should I get a lower voltage transformer or use the 25 volt one I have? |
#2 |
Yes, get an 18v traffo, or use a regulated supply to bring down the voltage on the one that you have.
The truth need not be veiled, for it veils itself from the eyes of the ignorant. |
#3 |
that looks like it might be a 4ohm Bass/mid driver and an 8ohm treble with a Zobel on it to reduce HF impedance.
This style of 4 to 8ohm has become very common. A chipamp must be designed as a 4ohm capable amplifier to drive these effectively. 18Vac, as Nuuk says, is about right.
regards Andrew T. |
#4 | |
Thanks for advice! I'll get an 18v xformer. |
#5 | |
Go to mpja.com |
| Switching 230 Volt Transformer to 120 Volt | OMNIFEX | Parts | 10 | 6th April 2008 05:34 PM |
| Rail voltages from 15-0-15 volt transformer | Bama Slamma | Power Supplies | 3 | 26th November 2006 11:27 AM |
| Need advice to chose best toroidal transformer for LM3875 monoblock? | Norris Wilson | Chip Amps | 6 | 25th August 2004 11:58 AM |
| 70 volt transformer failure | navigator | Multi-Way | 0 | 29th December 2003 01:38 AM |
| 30 Volt 5 Amp Transformer? | pixie | Solid State | 7 | 1st February 2001 04:43 PM |
| Page generated in 0.08169 seconds (67.80% PHP - 32.20% MySQL) with 11 queries |
