00.00 chipamp revealed
Old 22nd February 2009, 03:56 AM   #11
jackinnj is offline jackinnj  United States
jackinnj's Avatar
One of my Linn amps (Majik) uses a chipamp -- and it sounds wonderful -- driving biamped Kelidhs's.
Like so much else in life, don't knock it until you've tried it.
Old 22nd February 2009, 05:41 AM   #12
JZatopa is offline JZatopa  United States
I don't think anyone is knocking chip amps, I think they are knocking the price. I can't believe that this is selling for $7500, I feel insulted somehow by that price. I may be in the wrong business, I should start selling t-amps in a CNC machined copper enclosure for $10,000. "The copper's magic allows the t-amp to produce it's lucid musicality" ROFL.
Knowledge is Power & Applied Knowledge is Freedom,
There is no higher religion than truth
Old 22nd February 2009, 09:27 AM   #13
CJ900RR is offline CJ900RR  Sweden
Would you buy a Class-A transistor amplifier for that price? I mean, its only power-transistors
Old 24th February 2009, 02:16 AM   #14
sendler is offline sendler  United States
Default LM4702 application notes
Originally posted by jaudio
LME49810 or LM4702
Now I found the nice application notes for the LM4702 which would also apply for the 49811.
http://www.national.com/an/AN/AN-1490.pdf
Great notes they put together for that chip. It actually discusses differences in the circuit based on listening! No wonder they fired all of those guys. We can't have any of that going on around here.
I will probably give those a try as well before I commit to boards for the 7250. But so far, it has beaten all comers.
Scott
Old 24th February 2009, 07:51 AM   #15
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Sendler,
how about a 4-deck Jeff Rowland Model 12 with twelve LM3886T/Ch. for $14K, £14K, or €19.5K ?
Take a guess what the 2-decker with 10 chips cost overhere up till 5 years ago.
Old 24th February 2009, 12:26 PM   #16
jackinnj's Avatar
Default Re: LM4702 application notes
Make sure you take a look at the nat semi thread -- as Bob Pease recommended a noise-gain compensation tweak which benefits the chips -- 4702 and its single cousin -- even further.
Old 26th February 2009, 11:14 AM   #17
AndriyOL is offline AndriyOL  Ukraine
Interesting if it's possible to get the schematics of Jeff Rowland chipamps?
Old 26th February 2009, 11:18 AM   #18
pacificblue is offline pacificblue  Germany
The next best thing.
If you've always done it like that, then it's probably wrong. (Henry Ford)
Old 26th February 2009, 11:20 AM   #19
Default The shine7 link shows a schematic
The Shine7 link in the first post shows his schematic which would be pretty close to the Rowland layout.
Scott
Old 26th February 2009, 05:32 PM   #20
Default Re: The shine7 link shows a schematic
Except that the Jeff Rowland design is not inverted and therefore most likely doesn't have the same risk for some problems as the Shine7-design. And also the Jeff Rowland does not use DRV134 to bridge the two half's, as the DRV134 can also be a problem and is not suited for the job.
Note that I write "can". Many may not experience problem's but there is a possibility.
00.00 chipamp revealedHide this!Advertise here!
Sansui G-7500 help needed 1978chevyman Solid State 3 15th April 2008 10:47 AM
sansui g-7500 pezza89 Solid State 0 15th April 2008 10:36 AM
Tuner Sansui Tu-717 & Tu-7500 oldmarantz Analogue Source 4 2nd November 2005 05:28 AM
Sansui g-7500? Jasmeleg Solid State 9 7th September 2005 08:36 PM
Onkyo DX-7500 Schematic culcanmar Digital Source 1 22nd February 2003 03:32 PM
