| Chip Amps Amplifiers based on integrated circuits |
This is meant as a flexible, good sounding amp for my home theater. I've almost completed building the 10 mono kits, and have my 800W 20V toroid already. I plan on making a MDF enclosure, and have the top vented using perforated aluminum sheet:
![]() For cooling, I was planning on using an extruded aluminum square bar, measuring 14.5"x1.5"x1.5", then have aluminum plate on top of that allowing me to add heatsinks that I already have. Here are the pictures of my progress thus far. ![]() ![]() ![]() ![]() Comments/tips/questions would be appreciated. Thanks .
#2 |
#3 |
Primary wiring looks OK. As long as each secondary has the same voltage, you'll be fine with that.
#4 |
WOW
Aggressively Passive |
#5 |
Are you aware that a 2*20 V transformer will not turn the LM3886 into a 68 W amplifier?
Expect ~22 W into 8 Ohm or ~43 W into 4 Ohm per channel.
If you've always done it like that, then it's probably wrong. (Henry Ford) |
#6 |
If you are going to be running all 10 boards off the one transformer, why bother paralleling the secondaries? Why not run 5 boards off each pair of secondaries?
#7 |
Pacificblue, no I was not aware of that. This was not explaned in brianGTs guide if I read it correctly. Why is it that I will not get 68w?
Moose, I have 4 pair of secondaries, so I'm having a little bit of a time figuring out how to wire them. |
#8 | |
You have 4 secondaries, or 2 pair's of secondaries. Each rectifier board needs 2 secondaries.. Blue/Green AC1 and another Blue/Green AC2. |
#9 |
Hi Krips,
Take a look at the datasheet for the LM3886 at: LM3886 Datasheet On page 14 in the bottom left is a graph entitled "Output power vs Supply Voltage". There are three plots for 4ohm, 6ohm and 8ohm loads (left to right). To get 68W on a 4ohm load, you need +/- 27V DC, and to get 68W on an 8ohm load you need +/- 36V DC. 20V AC gives you approx 28V DC after rectification and filtering, which will give you about 40W into 8ohms. 20V DC (14V AC) gives you the 22W pacificblue was talking about. Recommended transformers for the 3886 into 8 ohms are 20-25V AC (28-36V DC) which give 40-68W into those speakers, so you are fine as long as you are not expecting 68W per channel. As far as the secondary wiring goes, there are lots of ways to wire to it to make it work, and each one has its advantages and disadvantages. I would read around the forums, as there are lots of people who have build multi channel amps. Once you have done your research post a diagram of what you think you want to build here. You will get lots of good feedback, and some back feedback and flames too (which should be ignored). The key is there is more than one correct way to do it, but there are lots of ways to do it wrong which could damage your parts, your speakers, or yourself! |
#10 | |
| Help identyfing capacitors on lm3886 briangt | Mr. Julius | Chip Amps | 6 | 15th January 2009 07:45 PM |
| LM3886 BrianGT amp complete, slight hum | wigginjs | Chip Amps | 34 | 5th March 2008 10:55 AM |
| Building an LM3886 BrianGT Kit -- Questions | wes-ninja250 | Chip Amps | 10 | 29th September 2005 12:35 PM |
| BrianGT's LM3886 board, and hiss | Russ White | Chip Amps | 9 | 20th March 2005 08:10 PM |
| BrianGT's LM3886 Kit | scott_jcp | Chip Amps | 11 | 4th March 2005 07:07 PM |
| Page generated in 0.12040 seconds (77.13% PHP - 22.87% MySQL) with 10 queries |
