Old 6th March 2009, 10:41 PM   #91
bobodioulasso's Avatar
Finally i think that in the doubt , it is a better choice to connect pin 3 to input/clean ground: little current will flow there, so, the risk to pollute this ground is small. In AN, they even permit themselves to use this ground for decoupling the LME supplies for the same reason i suppose. At the opposite, if you connect pin 3 to dirty ground, the risk to pollute the input stage ground with high current is big.
Forgive my english
Old 7th March 2009, 08:20 AM   #92
i found this that contradicts what i just said scroll down)
http://home.mira.net/~gnb/audio/lm4702.html
I find a good idea to connect separately pin 3 to the star ground.
Old 7th March 2009, 10:52 AM   #93
Default Re: AN-1850
Originally posted by Segran
It would be nice if anyone with the appropriate measuring equipment can quantify the difference.
http://www.diyaudio.com/forums/showt...60#post1716260
If you've always done it like that, then it's probably wrong. (Henry Ford)
Old 18th March 2009, 02:39 AM   #94
Default lme49830
I have finished a four-channel version of the lme49830/IRFP240/9240 with a "Green" feature. Exploiting the dual-voltage transformers available, I can switch between 22 volts and 44 on the rails with a constant 8 volt oversupply for the chip's power. I added an optoisolator with a 100K resistor in series and apply that to the base and collector of the Vbe multiplier. In the Green setting, the amp idles at 40 mA with the 22 volt rails, i.e. less than two watts per unit. In the hot mode it runs at 200 mA and 44 volts or the rails, for quite a bit more standby power. The idea here is to have the option for no-holds-barred performance, but leave the amp on for background music most of the time. The green mode is enough power and low enough distortion for all but the most demanding applications, given efficient speakers.
Old 18th March 2009, 09:57 AM   #95
Default Re: lme49830
A manually activated ClassG amplifier.
What a nice idea.
Let's all go green.
regards Andrew T.
LME49830 PCB design berni8k Chip Amps 14 20th July 2009 05:45 PM
Lme49830 enzedone Solid State 6 21st February 2008 04:26 PM
Page generated in 0.09217 seconds (70.79% PHP - 29.21% MySQL) with 11 queries
