Old 8th February 2009, 01:53 AM   #1
Question What do you think about this LM3886 desigh?
Hi
A friend of mine just gave this LM3886 schematic to me. Probably not the most simplify gainclone I ever saw... I need some feedback from anyone who thinks there's improvement can be made....and do anybody think this is a good design for the LM3886TF ??? Advice and recommendation is much appreciated...
Old 8th February 2009, 07:55 AM   #2
ratza is offline ratza  Romania
ratza's Avatar
This design is useless. Why don't you use the schematic from the data sheet of LM3886?
Any solution is a compromise.
Old 8th February 2009, 01:22 PM   #3
jazzy939's Avatar
ratza,
Useless in what way?
Old 8th February 2009, 01:58 PM   #4
I suspect the designer did not know what effect each component had on the performance of this amp.
If the builder does not understand the operation of this specialised schematic then steer clear.
I would not entertain it.
regards Andrew T.
Old 9th February 2009, 12:06 AM   #5
wow...that much....!!!
you mean a simplified LM3886 circuit is better than this...?
Old 9th February 2009, 03:43 AM   #6
ratza how do you tell this is a useless without hearing it???? Does theories good enough to judge the quality of it....I'm very curious... ???
Old 9th February 2009, 03:21 PM   #7
ratza's Avatar
It's easy to explain how it will sound, by just looking on the negative reaction. It will boost the frequencies under 100Hz, it can literally blow your speakers. This might be a poor attempt to create a subwoofer amplifier.
Old 10th February 2009, 02:55 PM   #8
Well... looks like committing a suicide here.
How about this one...he got two circuit and this is suppose to be a simplified version from the first one...any critics.
Old 10th February 2009, 04:55 PM   #9
ratza's Avatar
That's exactly what I use (and many others, I think), except that the 470uF capacitors are 330uf paralleled with 100nF ceramic.
Old 11th February 2009, 12:26 PM   #10
Hi
I have a LM3886 and
I have a 25-0-25 Transformer = approx +/- 35v, could I use the above circuit, or would it need modifying slightly
Thanks for your time
Ron
LM3886 and +-42V Semir Chip Amps 6 23rd September 2007 07:00 PM
Lm3886 MadFinn Chip Amps 9 1st February 2006 12:07 AM
I need a little LM3886 help segasonicfan Chip Amps 30 22nd September 2005 03:06 PM
Are two separate lm3886 = 2*lm3886 in parallel or bridge mode rs1026 Chip Amps 11 21st October 2004 10:24 AM
could John Audio re-desigh the Trace elliot TDA 1514A layout RIC Chip Amps 1 27th December 2003 04:39 PM
Page generated in 0.10525 seconds (77.98% PHP - 22.02% MySQL) with 10 queries
