| Chip Amps Amplifiers based on integrated circuits |
I have mounted four TDA1554Q on 2x6" heat-sink. It becomes very hot within 5min. I have to install this all circuit in sub-incloser. If I mount a FAN on heat-sink is that right way ?
OR How big the heat-sink is required for those four IC ? ( I am using 12V - 5 Amp. supply ) |
#2 |
Pd = U² / (2 * PI² * Rl)
Treat Rl as if it were 2 Ohm to compensate for the internal circuitry that gets 11 W out of 14,4 V. I. e. 12 V and 2 Ohm -> 3,65 W / channel -> 14,6 W / IC. Assume an ambient temperature of 50 °C in the enclosure. 150 °C is the maximum permissible temperature. (150 - 50) / 14,6 = 6,85. That is the thermal resistance you need to achieve. The IC has 1 K/W, add 0,2 K/W for thermal grease. Your heatsink must remain below 6,85 - 1,2 = 5,65 K/W per IC. For four ICs it must be a quarter of that ~1,4 K/W. Something like keyword SK85 from this site. This is assuming that you increase the power supply to double the size. With the 60 VA you have now, you can expect about half the possible output power, half the power dissipation, and a short service life, because it will be overloaded most of the time.
If you've always done it like that, then it's probably wrong. (Henry Ford) |
#3 |
Thanks,
Being poor knowledge in electronics, I could not understand properly. You are requested to help in general way please. In details. 1 IC (Stereo) 22w for Front Left woffer (20watt 4 ohm Speaker) 22w for Front Left tweeter (20watt 4 ohm) 2 IC (Stereo) 22w for Front Right woffer (20watt 4 ohm) 22w for Front Right tweeter (20watt 4 ohm) 3 IC (Stereo) 22w for rear left full range (20watt 4 ohm) 22w for rear right full range (20watt 4 ohm) 4 IC (Stereo) 22w for bass unit 1st driver 30watt 4 omh 22w for bass unit 2nd driver 30watt 4 omh 12-0-12 / 5 Amp Transformer supply. Its sounding good for me. But I don't know how it is reliable? and I could not run this circuit more than 15 min continuesly. I don't think it is overheating, but I wish to keep it as possible as cool the heat-sink. If I add fan on the heat sink inside the bass incloser, it may disturb the bass wave ? Pl. help again. |
#4 |
10"x4" is what you need, and a fan is also desirable to keep heat in check
![]() PB has the best suggestion - if you can't understand it maybe you need to read a little more - try Decibel Dungeon. And Rod Eliot's ESP website. Both excellent references. 2"x5" is too small for anything, try the one PB has linked to as a guideline for something you can get locally. You can also use a fan, sometimes the effects are quite dramatic. You need to have a secondary supply for the fan, preferably with a separate transformer, to keep electrical noise out of the audio system. |
#5 | ||
You have two choices, calculate for the worst case or Trial-&-Error, i. e. wait and see, if it works. If you want to calculate, with those increased numbers your Pd will be ~6 W per channel -> 24 W per IC. You need ~4,2 K/W max per IC -> ~3 K/W heatsink per IC -> 0,75 K/W heatsink for all ICs together. The heatsink from the above link at least 100 mm long will get you on the safe side. A fan will bring the necessary heatsink size significantly down. If you want to try and see, just wait for the thermal protection to switch the ICs off. It will probably happen on a hot day, when you listen to very loud music. Then decide, if you can live without music on all days that are hotter than that or increase the heatsink size. Quote:
#6 |
Many many thanks to both of you.
I purchased single transformer which has thee out i.e. 12-0-12 to make DC I used 2 Nos - 6amp Diod & 2 Nos - 4700 mfd 25V Capacitor Pl. find the attached picture. |
#7 |
That would result in a very inefficient power supply, wasting about half of the potential. A better solution is this.
![]() You need 2 rectifier bridges 6 A or bigger (or 8 diodes). Buy them big, they are cheap. And a big capacitor. You can use two, like in the drawing, but one bigger capacitor will do the same. Your 2 times 4700 µF are a good value to start with or 1 time 10.000 µF, choose the cheaper solution. If you can afford bigger values, go for it. It usually brings improvements in the bass.
#8 |
Thanks to pacificblue
As you had posted about heat sink 8"x4", I purchased, installed & found heating problem solved at all. Thanks again. I read your earlier post for power supply & I am going to build my new PSU as per your design. I going to continue this thread to ask NEW question bcoz you know my new PSU & power amp (TDA1554q). I need buffer amp/preamp to improve my poor input signal to amplify with TDA1554q. I found some website for buffer amp / active filter but supply was 15V & you know I have 12V. If any matching buffer circuit in your mind Please Post. Thanks & Regards. |
#9 |
The gain of the TDA1554 is 10. Line level should be 775 mV, which would result in 7,75 V at the output or 15 W with 4 Ohm speakers. Any normal source should be able to send the TDA into clipping.
What source do you use, that cannot deliver the 775 mV standard line level? You don't have 12 V. The transformer has 12 V. After rectification and smoothing you get ~(1,41*12)-1,4 which is 15,5 V nominal. You can use nearly any buffer/preamplifier with a single supply as well. You will need a virtual ground / rail splitter for single supply operation. In this article there is a section that explains how to use a single power supply on an opamp.
#10 |
Thanks, you are educating me.
I understood, now I have 15,5 V Power Supply. (WOW) As you stated TDA's output is 15Watt, & in datasheet stated 22Watt. i.e. I am doing something wrong. What should I do to get full 22Watt on 4 Ohm Speaker ?. <WHAT SOURCE DO YOU USE > = I am using Chip DVD Player 5.1 (Six channel) <LINE LEVEL SHOULD BE 775 mV> Sorry, you know my knowedge level, i.e. 775 mV I can not tell you. My DVD Players output has 6 Channel & accept SUB all channel sounds good. Sub sounds, but very poor. I thought, mono buffer amp may solved subs poor singal. Is that right ? Yes, I am going to study your posted LINK. Regards. |
| Standing waves in midirange encloser and pyramids on encloser's walls-what dimension? | GrzMiL | Multi-Way | 4 | 10th April 2006 06:05 PM |
| Ported Encloser | HeyYha | Multi-Way | 4 | 5th April 2004 01:59 AM |
| Page generated in 0.13040 seconds (78.30% PHP - 21.70% MySQL) with 11 queries |
