Old 3rd February 2009, 06:32 PM   #1
Send a message via AIM to shon35us Send a message via MSN to shon35us Send a message via Yahoo to shon35us
Question Heat to board
Does anyone have a good suggestion ok diy guide on how to mount the heat sink to the PCB?
Old 3rd February 2009, 09:09 PM   #2
mjf is offline mjf  Austria
hello.
what kind of heatsink is it?
greetings...........
Old 4th February 2009, 02:26 AM   #3
3 by 5 inch
Old 4th February 2009, 09:12 AM   #4
hello.
if you want to fix transistors or opamps you will drill some holes in the heatsink i think.
so you may fix the heatsink with screws on the board.perhaps you can use self tapping (or self drilling) screws,or use a steel cavity fixing for the screws..............
annother method is fixing with glue but i do not like it very much because the glue " gets dry" and crumbles after a longer time.......
Old 4th February 2009, 12:02 PM   #5
Default Okay
Because I was thinking about using an L bracket:
http://www.mcmaster.com/#1556a24/=gdx6g
and self-tapping screws:
http://www.mcmaster.com/#90087a192/=gdy1j
I hoping to find a guide on the form or the web that would help show thing like this
Old 5th February 2009, 03:37 AM   #6
raypalmer's Avatar
I wouldn't use self-tapping... The heads can torque off the shaft and then you've got yourself a difficult-to-remove problem on your lovely heatsink. Run down to a tool shop and buy a drill bit, corresponding tap and a tapping tool (if you don't have a good-quality powerdrill with clutch).
The upside to this investment is that the tap will more than likely prove itself useful time and again.
Wherever you go there you are.
Old 5th February 2009, 03:45 AM   #7
Iain McNeill's Avatar
I've seen spring clips used as well but on smaller sinks. You might have to screw the clips to your heatsink anyway
Sure Electronics New Tripath Board 4*100W class-D Amplifier Board 7788q Class D 312 18th May 2012 01:32 AM
Board to board soldering: BGA/SMD style NeoY2k Parts 0 7th December 2008 04:36 PM
My Cambridge 500SE, needs an output board (to replace internal DAC Board) slbender Digital Source 0 15th May 2008 01:36 AM
Lost 1 Zv4 ckt board..looking to buy 1 circuit board Blues Pass Labs 1 22nd March 2004 10:09 PM
Page generated in 0.08039 seconds (76.00% PHP - 24.00% MySQL) with 11 queries
