Old 3rd February 2009, 10:49 AM   #1
Tripmaster's Avatar
Default Transistor Question
Hello
I am currently building the Pedja Rogic’s discrete power supply for my dual mono Chipamp LM3886.
I have assembled the V+ section of the power supply and have started positioning the components for the V-. I have just noticed the component supplier has sent three types of BD140 Transistor.
BD140, BD140-16 and BD140-16R4
Is it ok to use a BD140 and a 16 in the same circuit?
It looks like they are also from three different manufactures.
Thanks for your help
Richard
Old 3rd February 2009, 12:16 PM   #2
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
Not sure Richard. Best to ask Cricklewood!
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Old 3rd February 2009, 12:31 PM   #3
Tripmaster's Avatar
Hi Nick
I was really unimpressed with their attitude when I chased a late delivery. I wanted to be armed with the facts before I call them.
I’ve looked on various spec sheets but cant seam to find any useful information.
Richard
Old 3rd February 2009, 12:57 PM   #4
Tripmaster's Avatar
I just called Crinklewood and spoke to Chris who was very helpful
‘-16’ refers to a plastic back transistor and ‘R4’ is the metal back version.
He also said all of the transistors regardless of make will perform in exactly the same way.
Old 3rd February 2009, 02:38 PM   #5
lineup is offline lineup  Sweden
lineup's Avatar
Yes, they are basically same transistor.
There can be some variation in HFE, gain.
BD140-16 .. is the most usual, lowest gain class ( ~160 )
BD140-25 .. is a class for those exemplars with higher gain ( ~250 )
BD140 .. only, can be in any gain span, is not classified and marked
with any of the above
Personally I have never seen any marked R4. The metalback.
lineup
Old 3rd February 2009, 03:54 PM   #6
Tripmaster's Avatar
Thanks for the info.
Would you recommend I change them all to the same type?
Richard
Old 3rd February 2009, 04:02 PM   #7
mjf is offline mjf  Austria
hello all to you.
the number behind the bd 140 - designation is the hfe-classifikation,there are some from 6,10,16,..............the bigger number means the greater hfe-value.
what hfe - (minimum )value you need depends on your circuit design..........
greetings.........
Old 3rd February 2009, 04:37 PM   #8
Tripmaster's Avatar
Originally posted by mjf
hello all to you.
greetings.........
Hello again
I am building the power supply schematic at the bottom of this page
Discrete Regulated
http://myweb.tiscali.co.uk/nuukspot/...p/supplies.htm
Richard
Old 3rd February 2009, 05:02 PM   #9
hello.
the schematic with the three-transistor-darlington?- i think this will give you enough current amplifikation (high hfe - value......).
but perhaps there will be a little problem with the heat-dissipation with loud music,i did not calculate it but i think yuo will need big heatsinks........
greetings.........
Old 3rd February 2009, 05:20 PM   #10
Tripmaster's Avatar
hello.
greetings.........
So just to recap, can I use a BD140 and a BD140-16 side-by-side in the V- supply?
I was going to make some heat sinks like the ones in Nuuks picture.
Transistor testing question woody Solid State 0 10th October 2008 04:08 AM
transistor question mike49504 Car Audio 9 10th April 2007 10:59 PM
transistor compatibility question Clipped Car Audio 3 3rd March 2007 02:29 PM
Aleph2 Transistor question! JarreYuri Pass Labs 2 26th October 2006 12:29 PM
Electrical Transistor question??? sbisdabomb Parts 3 7th April 2005 05:51 AM
Page generated in 0.10925 seconds (79.83% PHP - 20.17% MySQL) with 11 queries
