Transistor Question
Transistor Question
Old 3rd February 2009, 06:43 PM   #11
lineup is offline lineup  Sweden
lineup's Avatar
No problems.
Like told.
Any variant BD140 will do well
When you use one aluminum piece heatsink per transistor, there can be no shortcut.
Even if using no TO-126 transistor insulators.
Just do not let those heatsinks come into electrical contact.
If you use eletrical insulators for mount transistors, then is no issue.
Can not be shortcuts whatever.
lineup
Old 3rd February 2009, 07:05 PM   #12
mjf is online now mjf  Austria
hello.
yes,you can use bd140 ,.............;
I think the heatsinks are too small,they will run hot.be carefull when you power up..........
greetings..............
Old 3rd February 2009, 08:32 PM   #13
Tripmaster is offline Tripmaster  United Kingdom
Tripmaster's Avatar
Originally posted by lineup
No problems.
Like told.
Originally posted by mjf
hello.
Thanks guys
Crikey those transistors must get hot! Nuuk's used quite a lot of metal on his heat sinks. There must be about 9mm attached to the back of those transistors, and that's not including the bracket to both sides.
Richard
Old 6th February 2009, 10:04 AM   #14
measure the voltage drop across the pass transistor.
Measure the current through the pass transistor.
Multiply Volts * Amps to arrive at Watts. Choose a heatsink to suit.
regards Andrew T.
Old 6th February 2009, 04:33 PM   #15
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
No they don't get hot at all. But Pedja told me to heatsink them and that's what I made up from scraps of aluminium lying around the bench.
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Old 6th February 2009, 08:55 PM   #16
Tripmaster's Avatar
Friends in high places
Old 6th February 2009, 08:57 PM   #17
Tripmaster's Avatar
Thanks Andrew
I will do what you suggest just so I understand. I'm sure Nick's are just fine or he would have changed them.
Richard
Old 6th February 2009, 08:59 PM   #18
Nuuk's Avatar
Yes, he lives in a loft apartment!
Old 6th February 2009, 09:04 PM   #19
Tripmaster's Avatar
He must be popular with his neighbours!
Old 8th February 2009, 07:17 AM   #20
Tripmaster's Avatar
Hi Andrew
What is the formula to calculate the LM3886 power output? I will be using 2x300va transformers with 25v secondaires. Pedja's discrete PS has a dc output of about 26-27v. I am wondering if there will be enough power to drive my 8ohm 88db speakers.
I currently using an unregulated snubberized power supply, this is more than adequate.
Thanks again
Richard
Transistor QuestionHide this!Advertise here!
Transistor testing question woody Solid State 0 10th October 2008 05:08 AM
transistor question mike49504 Car Audio 9 10th April 2007 11:59 PM
transistor compatibility question Clipped Car Audio 3 3rd March 2007 03:29 PM
Aleph2 Transistor question! JarreYuri Pass Labs 2 26th October 2006 01:29 PM
Electrical Transistor question??? sbisdabomb Parts 3 7th April 2005 06:51 AM
