Old 2nd February 2009, 01:40 PM   #1
bluegti is offline bluegti  United States
Default LM3886 amp started blowing fuses. Where do I start?
I finished my dual-mono LM3886 amp based upon the boards from chipamp.com. Everything was working and sounding great for the last 2 weeks.
Last night I went to turn it on and no sound. I noticed the LED's were not on so I checked the fuse and it was blown. So I disconnected everything, replaced the fuse and everything came on.
So, I reconnected the pre-amp only and the LED's lit up when I turned it on. I turned it off, connected the speakers, turned it on and the fuse blew.
So, I disconnected the speakers, replaced the fuse and it blew the fuse again.
Then I disconnected everything, replaced the fuse and it blew again.
How do I start troubleshooting this?
Old 2nd February 2009, 03:02 PM   #2
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
Start by telling us what value fuse you are using - and the type!
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Old 2nd February 2009, 06:01 PM   #3
3 amp fast blow
Old 2nd February 2009, 06:09 PM   #4
Nuuk's Avatar
On the primary side? If so change it to slow blow.
Old 3rd February 2009, 04:16 PM   #5
a T3A fuse on 110/120Vac will start up a 100VA transformer.
What size is your transformer?
regards Andrew T.
Old 3rd February 2009, 07:18 PM   #6
I'm using Avel Y236503 160VA 22V+22V Toroidal Transformer
Old 4th February 2009, 07:22 AM   #7
Professor's Avatar
Fuse blow even if secondary winding connect to amp?
http://mymegahobby.jimdo.com/
Old 4th February 2009, 09:22 AM   #8
110Vac 160VA will require a T4A or T5A to start without a soft start circuit.
With a soft start circuit it will run on a T1A or T1.6A fuse
regards Andrew T.
Old 5th February 2009, 12:57 AM   #9
stpeter is offline stpeter  United States
Default Sometimes its better to be slow....
I agree with Nuuk.... If the fuse is on the primary side, it has to be slow blow
"Some notes on fuses: (a) It is best to use a "slow-blow" type in the power-line circuit, because there is invariably a large current transient at turn-on (caused mostly by rapid charging of the power-supply filter capacitors)." - The Art of Electronics ; Horowitz & Hill
Old 5th February 2009, 07:35 AM   #10
Default Re: Sometimes its better to be slow....
I think Horowitz and Hill are wrong here.
The purpose of the soft start resistor and/or thermister in the primary circuit is to reduce the start up current that establishes the flux in the transformer. Prior to this flux being established the transformer might try to operate as an air cored transformer and that produces very little if any output at the secondary
Horowitz and Hill are referring to the charging current and that can only flow after that start up flux has been established.
The best place for slowing down the smoothing capacitor charging is in the secondary circuit and requires a much longer time delay than the soft start.
Try an experiment:
use a >300VA transformer and find the largest fuse that blows when direct on line starting is used.
Now fit a timed delayed bypass across a soft start resistor. Set the relay time delay to 100ms. Does the charging of the downstream smoothing caps blow the soft started fuse? Can the fuse be made even lower and yet still not blow on start up? Remember to discharge the smoothing caps before doing these before and after experiments.
regards Andrew T.
Keep Blowing Fuses Whiting Tubes / Valves 9 11th September 2008 09:44 PM
Why are these fuses blowing Darin P-B Solid State 41 30th May 2005 10:56 PM
Blowing fuses balance Tubes / Valves 2 5th March 2005 02:16 AM
The Fuses Just Keep Blowing raffir Chip Amps 19 22nd June 2003 03:49 AM
Why does my PSU KEEP blowing fuses?! Rarkov Parts 29 17th October 2002 03:35 AM
Page generated in 0.10510 seconds (77.18% PHP - 22.82% MySQL) with 10 queries
