Old 30th January 2009, 01:34 AM   #1
Default LM3875 Transformer Question
I was looking to build an LM3875 classic kit from audiosector.com and am assuming that the kit does not include the power transformer. I need a 25+25v toroidal @ 160+VA for this chip, correct?
Old 30th January 2009, 07:07 AM   #2
Depends on your speakers. For an 8 Ohm speaker 2 x 25 V is okay. With 4 Ohm speakers you should not go above 2 x 18 V. Maybe 2 x 22 V with the unisolated package and a very big heatsink.
160 VA is liberal for one channel, and just enough for two channels at 2 x 25 V.
If you've always done it like that, then it's probably wrong. (Henry Ford)
Old 1st February 2009, 08:07 AM   #3
My LM3875 Amplifier works on TB4 Speakers with 24-0-24V EI-transformer.
The transformers are usually hotter than heatsink.
So I think that the voltage is OK for LM3875.
Old 1st February 2009, 09:05 AM   #4
Luck is offline Luck  China
Send a message via ICQ to Luck
Why not use a higher voltage and a bigger heatsink?yes,it works,but still not in the best way!
Old 1st February 2009, 05:33 PM   #5
Because the amount of heat the IC can dissipate is limited. From a certain point on a bigger heatsink does not improve the dissipation significantly anymore. See AN-1192 for that.
See also How To Heatsink.
24-0-24-5 transformer for LM3875 danielnaveen Chip Amps 7 16th December 2007 07:55 AM
Possible to use this transformer for LM3875 PS? Skitch72 Chip Amps 3 20th October 2007 01:59 PM
Transformer for LM3875 hayden123 Chip Amps 14 31st July 2007 07:35 PM
LM3875 Transformer hotscot Chip Amps 11 11th February 2006 12:03 PM
LM3875 GC Transformer cwoodall Chip Amps 1 7th September 2005 10:31 AM
Page generated in 0.07990 seconds (75.82% PHP - 24.18% MySQL) with 10 queries
