43mm, actually, maybe it's a custom order or something like that. Elfa is very weird with what they stock sometimes. And what one has to pay for it as well ...
Thus the worries for the heat. But I'm quite convinced I'll be fine, since nothing heated up too much on my early tests. I still have to see how it'll handle a long playing session though.
Don't worry, during tests, mine after a long listening session measured from 37° to 42° Celsius with both modules attached to a single panel...so with a surface that equals your two panels.
Atilla said:Now I've another small dilemma...
I wouldn't worry too much about it. The chips won't get very hot anyway and the toroids should remain just warm if not stone cold.
ClaveFremen said:If so I don't think you can reverse holes because of the bent that closes the back aluminum sheet:
Hi Atilla,
I was wrong, it can be monted to the other side placing the bent in the interior of case, obviously you loose the function of that bent in the back...
