| Chip Amps Amplifiers based on integrated circuits |
Hello everyone,
I'm new to electronic design so i need your help. I want to amplify the output of a DAC (TDA1543) in order to feed it after to a power amp and control the volume. I made some rough calculations and a schematic using an LM4562. Can you please have a look and give me some comments. Thank you very much |
#2 |
hi bluetech
you can use the IVY linestage in stereo configuration, look at the manual http://www.twistedpearaudio.com/linestages/ivy.aspx it sounds fantastic with opus dac
"I don't remember fighting Godzilla, but that's probably what I would've done" |
#3 |
With a 5 V single supply there will be no 2 V output. The output pp voltage will be less than 2,5 V. That leads to a maximum Ueff of (2,5/2)/SQR(2) = 0,88 V.
You should revise your output filter. The capacitors are much too small and they will form a high-pass filter with the following equipment. That means, the filter frequency depends on the input impedance of the power amp. Change the amp and the filter frequency changes. Not good. Therefore R34 and R36 should be connected between the capacitors and the output connectors. Then the filter frequency will be 1/(2*PI*R*C). With 100k and 80 pF you get nearly 20 kHz. Everything below that will be attenuated. You don't want that, do you? Very much the same applies to the input filter. Place a resistor (~ 5*P3 or bigger) to ground after the capacitor. Then calculate the high-pass frequency. For a bandwidth from 50 Hz upwards choose a filter frequency below 10 Hz. Take into account that the filters add up, so the lower the better.
If you've always done it like that, then it's probably wrong. (Henry Ford) |
#4 |
DAC output of 80mV doesn't sound correct.
Besides that, you might want to do some reading: http://headwize.com/projects/showfil...=opamp_prj.htm http://headwize.com/projects/showfil...=cmoy2_prj.htm The headphone amplifier is effectively the same as what you want. |
#5 |
Using such large resistance values raises two issues -- noise and stability. See National's product folder
#6 |
I wonder if the DAC output is 20mA?
20mA across 150r is about 3Vpk ~=2Vac But 2Vac is ~ 3Vpk ~ 6Vpp. Is the output from the DAC 20mApk or 20mApp? or something else?
regards Andrew T. |
#7 |
The output from the DAC is +/- 25mV, I think!
The DAC is the TDA1543 |
#8 | |
Regarding the voltage out, i have changed the gain to 400 to give an output of 1v (you said it will be 0.8). I may do a dual 5V suuplly at the end. I have changed the high pass at the output to 10Hz. I have added the 5*P3 resistors at the input even though i don't understand what they do. How can i set the low pass frequency at 20KHz? What is the SQR?? Thank you very much |
#9 |
Excuse but i don't know much about opamps.
I had a look on a book and made some assumptions. correct me if i'm wrong. Both filters on input and output should be high pass and for a required frequency of 50Hz I should set them to 1 fifth (10Hz) in order the 3db point to be approximatelly at 50HZ. The low pass frequency will be the highest frequency in the signal times the gain. Am i near at all? |
#10 |
Sorry, I have just decode the SQR thing, it's sruare root!
| LM4562 op-amp GB | novec | Group Buys | 285 | 26th June 2011 03:17 PM |
| FS: LM4562 (18 pcs) | theAnonymous1 | Swap Meet | 5 | 23rd May 2008 01:47 PM |
| Wtb/wtt: Lm4562 | cartman | Swap Meet | 7 | 26th November 2006 06:25 PM |
| National Semiconductor LM4562 used as a line preamp. | beppe61 | Solid State | 4 | 6th November 2006 06:54 PM |
| Lm4562 | Ryssen | Swap Meet | 0 | 12th October 2006 09:42 PM |
| Page generated in 0.13549 seconds (70.78% PHP - 29.22% MySQL) with 11 queries |
