| Chip Amps Amplifiers based on integrated circuits |
Could not find the exact answers to my questions in other threds, so i start one myself. I have just finished putting together my Chipamp from ChipAmp.com, and have some questions before i start mounting in the chassis. I have attached a pic of how i want to place things in the chassis, does the layout seem reasonable? Now over to the wiring, i have drawed it up as i have interpreted the manual, does it look ok? Isn't there gone be a ground issue with two transformers in one chassis? |
#2 | |
Don't solder your various ground connections initially. Solder on ring tags and bolt them together until you find the combination and order that gives the best performance within your system. Separate the Signal Ground from the Power Ground in each amplifier. If the PCBs don't allow this, then choose another PCB. However, You must make a permanent mechanical fixing from the third protective earth wire on the mains cable to the major part of the metal chassis. No terminal strips allowed, direct connection of input wire to chassis. Never remove this permanent connection, ever. You can add extra nuts and washers and connections above the permanent securing nut/s. This Safety Earth is for safety of the users/house/home/pets only. It will cause audio degradation when building multichannel amps. Minimise the degradation, do not remove the Safety Earth, that's your challenge when you don't go the monoblock route.
regards Andrew T. |
#3 | |||
By connecting the ground as i have skeched up will form a ground loop i suppose? Can i breake the loop by inserting resistors between star ground and Amp ground? or will that hve an influence on the sound quality? Quote:
![]() Sorry for all the Noob questions. Thanks for your reply, AndrewT |
#4 |
One more thing:
When you mount those toroids, be careful not to create a shorted turn with the mounting bolt and mounting brackets! The obvious approach for example of fitting a bracket at each and and running a bit of studding down the middle would be a disaster. BTDT. Regards, Dan. |
#5 |
Yes i was planing to use a mounting bracket and a bolt for each toriod, so that they would be seperated from eachother, and no shorted turn.
![]() But i will probably mount them in the standard way, not on the side, so i won't be a problem. But thanks for the warning |
| Layout advice for my 1st GC. | snknby123 | Chip Amps | 15 | 25th January 2009 12:26 PM |
| Wiring / Layout question | kacernator | Tubes / Valves | 4 | 23rd January 2009 07:29 AM |
| Advice about PCB layout | Yoshy | Parts | 0 | 8th January 2009 02:05 AM |
| UCD700 Layout and Wiring | GregD | Class D | 8 | 17th October 2006 04:05 PM |
| Aleph-2 PSU wiring layout question | moe29 | Pass Labs | 5 | 21st August 2003 10:42 PM |
| Page generated in 2.70982 seconds (-87.64% PHP - 187.64% MySQL) with 11 queries |
